Question about Sanyo DS25390 TV
Sanyo TV - DS25390
I just got this TV from a friend. It only has a cable TV outlet (no audio/video, etc.) How do I hook up my DVD to this television?
  • fcikelly May 21, 2008
    Same issue...got my tv from someone and can't hook up my dvd player. I'm hooked up to the satellite receiver just fine but the hookup of the dvd player through the sat. receiver is not working as it should according to the Satellite company tech support person i spoke with. I plan to purchase an RF Modulator to remedy the problem. Hopefully that solves it.
    New Friend:
  • 76 Answers
In your model you have to purchase one video RF converter. RF converter contains one video input in yellow colour and two audio input in red and white colour and one cable connector as output. Connect the dvd output to this converter and tune the tv program in which place you receive dvd signal.
Posted on Aug 27, 2007
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
How do i hook up a dvd player to a tv
Depending on what model tv and dvd player you have, it will be either HDMI (one cable for audio/video), RCA Yellow(video) red/white (audio), or Composite (3 for video and 2 for audio). Make sure you connect the cable you choose to the INPUT of your tv and then you have to use your tv remote to change the input (ex: hdmi 1, or aux, video 1 etc) depending on your model and input you choose.
Jun 23, 2012 | LG 42LG30 42 in. LCD HDTV
Tried to hook up hd cables and seems good but no audio tried to hook up but can't get to work
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" The DVD, Receiver etc, to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
Im trying to hook up my wii to my surround sound and i have a denon avr-789 and im hooking it up to the aux outlet and im only getting sound no video
Connect all of your cables to your display and then connect another set of cables to your audio variable out from the television to the input you wish to get sound from on the receiver. Then make sure your tv is selected to the input you plugged the wii into, for example, Front video or Video 1 etc etc.
Jun 06, 2009 | Denon AVR-987 Receiver
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Audio cuts out intermittently and tv only 10 months old.
Hook the tv up without the box then use dvd etc to test the sound
If the sound works find with dvd etc hooked up then its the box
Jan 20, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
DTV hookup for an RCA XL-100 TV
Buy a box modulator which have RF input then have RCA output that's input to your TV or other option below.
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
HP TVs - TV Cable and Connection Types
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
HOOK UP INFORMATION
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Connecting DVD Player
when you say nothing do you mean the tv wont come on? If the tv is on can you see the words (input, volume bar, menus, etc.) do you hear audio? does the player work on another tv, since you have a sylvania tv, are you using the game button on the top of the remote to switch to the jacks on the front? Good luck :0)
Jul 07, 2007 | Sylvania 6419TC 19" TV
Televison & Video Logo
147 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
