Question about Garden
Honda hf 2315 manual
Fails to start
Juki MO2300 Manual book
Search for:
Make Model manual
Apr 17, 2018 | Juki Sewing Machines
I have an H 300 propane heater showing an HF code, cleaned all gas orifices and replaced the ignitor. Still comes up with the HF code any ideas.
Here is an answer written by Stephen Dorje. I think it should help.
This means the flame sensor/ignitor has failed. You are either not getting spark or the burners are not igniting if you are getting spark, I would recommend replacing the sensor/ignitor. Pretty inexpensive and a fairly easy fix. Here is the owners manual for the unit (not Lo Nox)....
Hayward Heater Manual link
Answered by 8c79505.jpgStephen Dorje Over a year ago
Sep 03, 2011 | Hayward H Series Pool & Spa Heater 400k...
Looking to buy a 1988 Honda CRX HF. Automatic Transmission. I would like to do a 5 speed swap on it. What is needed, how hard would it be, and what would it end up costing me?
-5 Speed Transmission
-Clutch/Pressure plate/Flywheel/Hardware
-Clutch cable
-Manual pedal assembly with same options as your car (Cruise control2_bing.gif for example)
-Front, side, and rear transmission mount brackets from 5 speed car, and the actual mount for the rear (Regardless of what people say, it is not needed to drop the rear x-member to do this rear mount, but if you don't have a decent set of tools, you may have to do this to get to the rear bolt.)
-Manual axles. I think auto axles will work.
-5 speed throttle cable to match the the 5 speed pedal assembly
-Auto speedo cable will work.
-Connect the 2 larger black wires that go to the shift position switch in the automatic. These wires are for the starter. In the auto car, they are only connected when the car is in nuetral or park. Solder these two wires together and heat shrink. Use a **** connector if you want to just ghetto rig it together.
-You will get a code 19 and a "check engine light". This is for the torque converter lock up solenoid on the PS9 auto ECU (For my D16A6 Motor anyway, the 1.5 may have a different auto ECU). The car will still run and drive fine, but getting the manual ECU for you car, and cutting off the auto wiring from the harness will eliminate this issue.
-You will need to ground the Green/White wire from the shift indicator switch, this indicates that the car is in "park", and will allow you to remove the ignition key. The alternative is to swap to the 5 speed ignition switch, but you may not want to end up having separate ignition, and door keys if your car currently uses one key.
I have a HF 5 Speed ecu and a few other parts to if you need them
Price is hard to tell because of price of parts and places vary to do these swaps. Shops around here will covert a auto to manual for anywhere from 500-800 bucks labor only.
Jul 02, 2010 | 1989 Honda CRX
JBL EON15-G2--Does the HF Amplifer to the driver have any voltage?
The 2 leads that come off the HF driver are different sizes...you should only be able to hook them up one way. Takes the guess work out of it for ya.
Assuming there is nothing wrong with the speaker, hooking up the 2418H HF driver to it should do the trick. However, I blew my HF driver a few months ago and bought a new one, only to blow it immediately. This was because the motherboard of the JBL EON G2 had actually failed and caused the HF driver to fail. Once I replaced the motherboard and the HF driver (again) everything was back to sounding great. Hope that helps.
Oct 10, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Pds-2315 surround sound remote control
I am looking for a universal remote that will work the PDS-2315 someone please help
Jan 07, 2008 | Pds Hot Buy Store: PIVA DIGITAL 5.1 Home...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
