Question about LG 50PQ30 50 in. Plasma HDTV
Pcm settings tv - LG 50PQ30 50 in. Plasma HDTV
I have hooked up an older LG DVD Player with an HDM I cable to a new Vizio TV. I have picture but no sound
HDMI transmits audio using a digital format. Access the menu on the Visio TV and make sure that the HDMI input audio is set to ON or PCM. Also access the menu of your DVD player and make sure the audio output is set for HDMI Audio and PCM as well. These setting should ensure that the audio is passed over HDMI from your DVD to your TV.
Nov 11, 2017 | LG Televison & Video
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
Why can I not change the setting from pcm to dolby digital on my tv
You don't. You change the signal at the source device end, not the TV.
If you have connected a Blu-ray player or a games console, then set the device audio option to Bitstream. This will send a data stream to the TV that it will decode either as Dolby or DTS depending on the source signal format.
Dolby Digital is only an option for an external AV source connected via HDMI. That's the only way to get a Bitstream signal in to the TV. The TV's internal tuner is only capable of PCM audio. It's a DVB-T tuner (standard definition) rather than the DVB-T2 tuner needed for HD. Even then, only the HD channels are encoded in DD.
Iff your BD player or console is decoding to stereo PCM, then it's doing the same job as the TV. There's a small advantage with one of the audio processing modes in how it limits the dynamic range, but other than that PCM and DD will sound identical. This is especially the case with any TV that has no optical audio out, as in this case. The TV can't pass a DD signal out to an external audio system. So all sound is played via the internal speakers or headphone jack. It'll all sound the same, PCM or DD.
Oct 13, 2014 | Samsung Televison & Video
How to get audio on Phillips blu ray
If playing direct in to the TV, make sure the player's audio menu is set to "mixdown to PCM" or just PCM rather than Bitstream. The reason is that most Blu-rays contain audio in DTS format. But very few TVs can handle the raw Bitstreams DTS data feed. Let the player do the conversion to an audio format that the TV understands. PCM is pretty universal. It'll be just stereo, but that's okay because your TV probably can't do much more than that anyway.
Aug 04, 2014 | Philips Blu-ray Disc Player with Wi-Fi -...
Set tv pcm output
is it flipping back to Auto setting without you turn off the tv or unplug it ?
http://www.tvrepair.localdomain.me/
Jan 07, 2014 | Toshiba Televison & Video
How to connect a panasonic tcp50gt25 tv audio out (opictal) to a pioneer amp.with opitcal. i connect the cable but no sound,any idea for setting,i did the setting for optical on the amp but still no sound
What is the source? if you are using an HDMI connection from an HD source you should have digital audio. also, if you are connecting digital cable directly to the TV it will send digital audio out as well. check the optical cable at the amp end to see if it is working. it should glow red at the tip if it is.
there are digital input mode settings as well on some receivers. if it is set to DTS it won't work on PCM audio. if it is set to auto Digital it should work on any standard. check the PCM or DTS options in both the TV, and receiver if those settings are there.
Mar 12, 2011 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
I have comcast basic cable. Recently I have six channels (always the same ones) that don't have sound. All the other channels are fine. We have a small tv in the bedroom also connected to the cable and...
Try changing the audio settings in your tv. Sometimes changing from pcm to dolby digital or vice versa can get your audio back up on these channels. Remember some stations are broadcasting in digital pcm and or dolby digital. I would leave tv on pcm. If that doesnt work check to make sure your not in a second audio mode (meaning set is on sap) sometimes a customer will accidentally hit the sap button. Put unit on stereo setting
Oct 22, 2010 | Panasonic Viera TH-42PX80U Plasma TV
RCA DRC277-A, No sound when played through a Samsung HDTV using the HDMI chord. Chord and TV seem to check out fine. Tried all buttons and menus I could find. Have set sound to PCM, etc.
There might be a setting in your tv's audio menu to enable your audio source, which is now hdmi (vs. the rca-type red and white audio cables). Once you select the type of audio you are using, the audio, you should hopefully be able to get sound from your dvd player now.
May 31, 2009 | RCA DRC277 DVD Player
Ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Feb 06, 2008 | Televison & Video
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
LG 50PQ30 50 in. Plasma HDTV Logo
14 people viewed this question
Computer Repairing
Computer Repairing
