40tl868 toshiba BACKLIGHT LIT NO SOUND/PICT
NO SOUND OR PICT BACKLIGHT LIT GREEN LED ON FRONT LIT NO REMOTE OR LOCAL CONTROL FUNCTIONS.FIRMWARE PROBLEM ???? THANKS P.H.
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
mpaint
  • 36 Answers
SOURCE: RCA L42WD22YX5 TV green light but no sound/picture
Recommend opening it up and looking at the power board and see if there are any visible Bulged or leaking capacitors.
Bad caps are a major source of computer and LCD no post problems.
If you find em, then just find replacements with the same uF and voltage and solder them out/in.
Posted on Jun 28, 2010
budmrtn
  • 11361 Answers
SOURCE: Toshiba 22LV505 TV-DVD:
Check the DC filter caps in the power supply first. Check the 24vdc (or 18vdc for this 22" model) to see if it goes away when the screen goes black.
There are main AC fuse, backlight inverter fuses, T-CON fuses.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 08, 2010
  • 453 Answers
SOURCE: TV switches from green light to red light every 20
the problem on ur tv is the power supply if u take the back cover off and look close to the power supply u would some bad capacitors , 3 to 6 bad cap or it can be only one thats way the tv is not working , if u try to replace this bad cap the cost woulbe about $50 with the solder station or u can call a tv repair shop and see how mush cost to replace the bad capacitor on ur power supply but u has to take the power supply from the tv and take it to the repair shop
Posted on Dec 31, 2010
bugoy31
  • 1238 Answers
SOURCE: Hi, I'm giving you a full
Good day!!!
That problem is usually have 2 causes..Its either power supply board or main board..
But you said that you order PSU and realize that its not the problem...Since then the PSU is there I suggest to replaced it because the possibility of faulty PSU is big...Normally if the PSU got a voltage drop you can also have blinking LED and lit red...
But if the problem is still there after you replaced the power supply board...That problem could be on the main board..
If you need more clarification or query just add a comment and I will give the info you needed...
Thanks for using fixya..
Have a nice day!!!
Posted on Aug 11, 2011
Hello, I have Toshiba TV Model #47L7335D. When I turn it on, Green LED on front flashes green then No pic and sound
Main digital board fault. Check and replace it. In most cases a firmware update too might be necessary. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 28, 2017 | Toshiba Televison & Video
Toshiba led lcd
There is no 'bulb' in LCD/LED tv.
The back light is LCD or LED only.
The shopJimmy also point to the bad inverter and/or LED driver
you should evaluate the cost of part + age of tv vs new
Apr 03, 2016 | Toshiba Televison & Video
Toshiba regza 32av554d
There is a short circuit with any of the component/s at its main board. Contact any service technician. do not switch the set ON again and again. It might make things worse. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 05, 2014 | Televison & Video
How to enter factory code for LED 200 seires
You're asking about how to get into its service mode I assumes and posts this solution. Push simultaneously Power button on the front panel of the TV and UP button on the remote control for more than 5 seconds. This procedure may vary set to set, according to the firmware loaded to it. For more details, check this link.
Jan 15, 2013 | Toshiba Televison & Video
Samsung CXM1374 TV/VCR COMBO. The original rmote no longer functions. Changed batteries but still no functions work. Does remote or TV buttons have to be activated to reprogram?
you need to open the cover of your remote control..visually inspect the PCB for any loose connections/cracked board specially the battery terminals...solder any loose connections and if nothing happens replace the crystal oscillator from the remote control it is a square,color orange sometimes blue with a label on it its clock speed in MHZ. it is available at electronics supply store..you can use the camera of your cellphone to test whether the remote is working by just pointing the camera to the LED at the top of your remote once you press a button from the remote the LED should lit...means your emote is working...3rd test the LED/infra red if it is not busted..remove the LED INFRA RED from the pcb and using a multitester analog supply.set the tester to X1 range then supply the terminals positive negative with the test probe there should be a continuity connection and the LED should be lit.
May 20, 2010 | Televison & Video
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
Toshiba 2877DB
Before you do anything else, make sure you do a hard reset. Unplug your television for an hour or two and then plug it back in. If you are still seeing the blinking lights and no picture or sound then we know of several possible prolbems that it might be. All of which require a local repair service to open the tv and replace a part.
Thanks,
Jul 03, 2008 | Televison & Video
Sony proj tv,sound,green pict few seconds then shuts down
could be three different things.
1. could be the crt itself as a tube with dfective phosphure wil do this
2. could be the vertical ic on the crt board
3. could be the focus pac.  located in front of tv with 6 adjustment knobs on it.
Oct 06, 2007 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
