Question about Home
Not releasing steam when heated up - Home
    Problem Solver:
  • 7 Answers
Ur starting off with clod water rite ! Because u never put hot water into anything that steam cleans !( carpet , steam mop,iron)
Posted on Jul 12, 2013
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Shark press & release won't heat or steam
Yes, the heating element needs to be replaced which can be done by any competant electrician.
Mar 21, 2014 | Shark Press & Refresh Fabric Steamer...
My shark vac then steam will not steam anymore and I am doing everything right. How do I fix this problem?
im not familiar with that brand but i am an electrician and vac tech. i would if i were you i would check and make sure the heating element had power at its connection. if there is power replace the heating element. plenty of online vac parts stores have schematics along with a parts list to help you locate part in vacuum.
Feb 13, 2013 | Shark MV2010 Vac-Then-Steam 2-in-1 Vacuum...
Printer releasing steam after each page printed. heat coming from printer top
If steam is being released then the paper you are using is damp with moisture.
The fuser in the printer fuses the toner onto the paper, that process require a fair amount of heat.
Dry paper does not give off steam, use fresh dry paper.
Sep 02, 2010 | Samsung ML 2010 Laser Printer
I have a Shark Steam Mop S3501CO model. When I press the release button to exchange mop heads, the mop head does not release. Nils Friis
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That head can stick very tight...get someone to hold the head and you pull the mop...
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Aug 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Euro-flex monster baby 1000 watt will not release steam
try running a descale through the unit. probably blocked with mineral deposits. Descaler available at most steamer retailers
Sep 20, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
No Steam after heating up
Sounds like the switch on the handle or the steam release solenoid on the steam chamber is faulty ,use a volt meter/tester to see if you have current to the solenoid when you turn on the switch.
Dec 02, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Home Logo
476 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
