Question about Nelson LR Rain Train Traveling Sprinkler 1865
Squeaking sprinkler My sprinkler works fine, but how do I stop it squeaking all night and upsetting the neighbours? Seems to come from base of rotary head.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
WD40
Posted on Nov 18, 2013
Why is there a squeaking noise only when I drive at night
at night, it is cold, your drive belt gets worn other time, when it's cold at night it doesn't get much grip, so it squeaks, what you can do is tighten it up, find which one is loose by pressing on them. The concept of belt tensioning is simple, look it up, on all cars work the same.
May 05, 2014 | Daihatsu Cars & Trucks
Squeaking rotary noise from engine
It is possible you have a glazed belt - it is fine, it just slips until it warms up. If you have "V" belts, there is a belt dressing you can spray on that will cure the problem. If you have serpentine belts ( a wide belt that has several ribs on the inside ) you can us a small dab of Dielectric grease on the belt. smear a small dab across the ribs of the belt ans start the engine - the squeal should go away quickly.
Hope this helps!
Jan 25, 2014 | 2009 Jaguar XF Supercharged
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
How do I stop my phaser 3600 from squeaking?
Have you try to clean its gears? You can use some pressurized air (dust off), and a little of light oil (DW40) ONLY for metallic parts.
Sep 18, 2012 | Xerox Phaser 3600DN Laser Printer
Squeaking is definitely coming from the Ramp area either at top or lower. Hard to tell when I'm on it, and it does not squeak without weight on it...Everything seems to be fine outside of the squeaking....
Tip it over - there was a version that had a problem with the frame cracking where the ramp attaches. There is a kit to fix this, if that is what you find.
Jan 03, 2011 | Precor EFX 546i Elliptical Version 4
Phone wont vibrate
ok i dont know if this solves the problem for good, but i do know that it solves temperately. I went to phone settings and set the ring tone profile to vibrate. then i kept pressing the play button until the squeaking went away. It seems as though once the little moter in the phone goes at a constant speed it stops squeeking. the squeaking stops for a good while and is better than nothing. Someone tell me if this works for them. thanks ;]
Apr 17, 2009 | T-Mobile Wing™ Smartphone
HOW DO YOU GET THE SQUEAKING NOISE TO STOP
You must indicate where the squeaking is coming from. If its only squeaking, move on. There's other people here with down time problems. It'll stop squeaking or stop running eventually. If it stops working, then write in!
Mar 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Admiral Washing Machine Makes Squeaking Noise
THE BRAKE IS VERY FAMOUS FOR THAT NOISE NOT INSPECT THE PUMP ,, CAN BE GRINDING ON BOTTOM BASE OF WASHER ,, BEARING POPPED OUT
Nov 22, 2008 | Washing Machines
Nelson LR Rain Train Traveling Sprinkler 1865 Logo
152 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
