Question about Dell 5100MP Multimedia Projector
12V Relay trigger wont work
I have a Dell 5100MP Projector and i am trying to use the trigger function on the projector to lower to screen. I hooked everything up accordingly but it wouldn't work. I checked to see if i could pick up a voltage at the plug in the projector and didn't get a reading. Does anyone know of a way that fixes the trigger.
marsrover
  • 682 Answers
SOURCE: No signal on screen of Dell Projector 3200MP
start your laptop first then your projctor-if the problem still excit-press-control+f4 or control+f6 or control+f7
Posted on Mar 08, 2008
SOURCE: Won't project; can't find signal
What worked for me was instead of pressing Fn while pressing F8. I pressed Fn and F4. The first time doing this my laptop screen went black, but the image was projected on to my projector. When I did this once again the image then appeared on both my laptop and on my computer.
Posted on May 17, 2009
SOURCE: Dell 1100mp projector
need to buy the right projector lamp for dell 1100mp
Posted on Jan 02, 2010
SOURCE: How do I open the case of the Dell 5100MP
Remove the 5 recessed screws on the bottom and the two screwlocks on the m1 connector.
Posted on Apr 11, 2010
  • 567 Answers
SOURCE: When I use the remote to power on the Dell 4610X
Hi there this mean you remote "power on button" is not working you need to get it fix or if you prefer you can replace the remote.
Posted on Jul 27, 2010
My 5100mp has audio in and out ports how do i make use of these
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
http://www.lampdeng.com
Feb 28, 2014 | Dell 5100MP Multimedia Projector
My dell 5100mp is not getting signal from my IBM laptop
Hello.
Check your VGA cable (from laptop to projector) to be certain it is secure. Wiggle it to see if anything changes. Could be faulty.
Check the Function keys on the top row of your laptop. Note which key has "CRT/LCD" or an icon of a display. Hold down your Fn key and press that key. Try again and again and hopefully you will get a display from your projector.
Hope this helps.
Apr 08, 2010 | Dell 5100MP Multimedia Projector
Bulb Error
http://www.retrevo.com/support/Dell-5100MP-Projectors-manual/id/575bh227/t/2/
manual above. Also check, the Thermal Fuse, some have a little "Reset" button, to restore them check that. Also work through the troubleshooting section.
Mar 27, 2010 | Dell 5100MP Multimedia Projector
How do I open the case of the Dell 5100MP projector?
Feb 15, 2010 | Dell 5100MP Multimedia Projector
Dell 5100MP displays bands of color at the top and bottom of the screen. Light appears to show through the upper portion of the lens.
you have a collapsed light tunnel. it'll need to be replaced. but since dell doesn't sell the parts, you'll have to send it to them for repair.
Feb 03, 2010 | Dell 5100MP Multimedia Projector
Image is pink when you connect any laptop to the dell 5100mp projector
make sure the input is correct. chances are you have it on component. change it to computer (rgb).
Jan 20, 2010 | Dell 3200MP Multimedia Projector
I connect the projector to my dell laptop and "no signal" displays and no picture.
You need to hold down Fn (function) button and press F4 to route the video signal to the video port. It may be F5., If you have done that check to see if you selected the correct input on your projector through its menu.
Dec 26, 2009 | Dell 5100MP Multimedia Projector
Dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Sep 02, 2009 | Dell 2400MP DLP Projector
Dell 2200mp searching for signal
One problem may be that you must tell the PC to send the signal to the external monitor. Usually, if you hold down the function button and hit the F5 key you will see several options on the screen. (Other laptops use different function keys. Look for the one that shows two tv screens. You want the option which shows the laptop and the external monitor.) To advance between options, you hit the F5 button again and it moves over to the next option.
My computer needs me to lower the resolution on the laptop in order to send the signal to the projector. If you also need to do that, you can do it in Control Panel, Display, and Settings, and lower the resolution on screen number 1.
Doing both of these things should work.
Also, confirm that it is finding signals by hooking it to a DVD or video and see if it finds the signal through one of the other ports.
Sep 25, 2007 | Dell 2200MP Multimedia Projector
Dell 5100MP Multimedia Projector Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
