Question about Dryers
FRIGIDAIRE DRYER FEQ1452HSO
CONTROL PANEL IS BEEPING EVERY 15 MINUTES ALERTING TO START A CYCLE IN RANDOM SEQUENCES.TRIED EVERYTHING TO CLEAR . CAN'T FIND BOOKLET IT'S 4AM...
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
SOURCE: Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Posted on Apr 21, 2010
SOURCE: front load dryer frigidaire model
I have the same problem... please help.
Posted on Oct 29, 2010
KevinWhite
  • 1902 Answers
SOURCE: I own a Frigidaire electric dryer model no.
Hello
The beeping sound means that it is the thermostat that needs replacement. This thermostat is located inside the back cover panel on the blower wheel housing towards the exhaust duct. This problem can be solved once the thermostat is replaced, you can also test the thermostat with a ohm meter, you can check its continuity. Please get back to me if you have any other questions.
Kevin
Posted on Nov 15, 2010
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Frigidaire Dryer model # LEQ1442ES0. The lights come on and beep at us like normal when I change settings but when I press start, they just blink and beep but wont turn on.
Thank you for your post, friend!
From my understanding your Frigidaire dryer is not starting and the lights just blink. It sounds like a faulty door switch or control panel. I would check to make sure the latch or door strike is not cracked or broken if the door is not closing properly that could be the cause of your dryer not starting.
You could also perform a reset on your dryer and that could help clear any faulty error codes within your dryer. To reset your dryer you would unplug the power cord for ten minutes. I hope this has been beneficial. -Matt
Oct 17, 2014 | Frigidaire Dryers
Dryer will not start
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
-Best Regards-
WP
My frigidair affinity dryer wont start it just beeps
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
Leq1442eso
Good Afternoon Terry, thank you for your post!
Often constant beeping is an indication that the unit is experiencing a possible error. I under you have tried resetting the dryer by flipping the breaker. It is important to wait roughly ten minutes before turning on the unit. If the beeping continues, then the appliance could be experiencing a communication issue with the control board or a potential wiring failure. I would recommend connecting with a qualified appliance repairman to proceed further.
Aug 29, 2013 | Frigidaire FEQ1442ES Electric Dryer
The Dryer says Control Locked how do I fix it
Which brand/model of dryer do you have? For most dryers, you need to press and hold either one button or a pair of buttons at the same time to toggle the lock on and off. Frequently the correct button or pair of buttons will be indicated with a small padlock or child's face. Some LG dryers are nice; the button is labeled Lock/Unlock. Press and hold the button for 3+ seconds until you hear a beep and see the alert go off. The Whirlpool Duet (and the Kenmore equivalent) require you to press and hold the End of Cycle button for 15 seconds. On at least some Frigidaire dryers, press and hold Select and Options for 10+ seconds.
The control lock prevents someone from changing the settings or starting the dryer running when it shouldn't.
If the appropriate steps for your washer fail, try unplugging the dryer for a while. If the lock remains enabled, the control panel isn't communicating properly with the board. Either the panel will need replacement or the board itself.
I hope this helps.
Jun 16, 2013 | Dryers
Dryer randomly beeps, like morse code and changes ...
sounds like a stuck or shorted membrane switch.
which would require replacing the console. if you can access the tech guide in the control panel you can do a membrane switch test and other diagnostics.
May 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Dryers Logo
67 people viewed this question
Top Dryers Experts
