Question about Garden
Cub Cadet 933E won't start with key
My Cub Cadet 933E (Model 12AE751-100) Wide Cut Mower won't start with ignition key. This problem began after I last power washed it. I have replaced solenoid, voltage regulator, and ignition switch to no avail. Battery tests out fine and I have checked all terminal and plugin connections. Mower starts and runs fine when started by pull rope.
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 109 Answers
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Posted on May 03, 2009
woobie dog
  • 1273 Answers
SOURCE: Riding mower won't start from key switch
Do you have power to the switch? This is the only thing that jumps out at me, as you already did the right things.
Check that. I bet it'll get you going!
Regards, --W/D-- Feel free to rate my answer.
Posted on Jul 24, 2009
  • 133 Answers
SOURCE: cub cadet LT1018 won't start or crank
It might be a saftey problem. But before you start changing swithches or whatever try this. If you have to lift a lever to engage the PTO for the blades try wiggling it up and down a little bit while sitting on the tractor and the brake pedal depressed and turning the key to start it.
Sometimes there is a little wearing and it won't be in the right spot on its own.
Good luck and let me know if this helped.
roundo4
Posted on Aug 08, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Removing lawnmower blades
check the belt that goes from each blade there is a timing mark on them
Aug 28, 2012 | Mtd Cub Cadet 33 In 344 CC Wide Area Cut...
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet model 1520 won't start.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Jun 09, 2012 | Cub Cadet Garden
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
No spark cub cadet 933E changed plug still no spark motor cranks fine
you may want to check the coil. under the coil there is a wire (kill wire) unplug it. try to start it, if it starts you have a bad wire somewhere. if it don't the coil is bad and needs to be replaced.
Nov 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
