Audiosonic 5.1 Home Theatre suddenly started making popping sound and wont work.
Audiosonic 5.1ch Home Theatre started making a rhythmic popping sound while on standby in middle of night. I turned it off at the wall and went back to bed. I turned it on this afternoon, and it is still making the "pop" sound every second and a half or so, through every speaker and the sub-woofer. There is nothing on the display, and the buttons don't work.
Kimi
  • 277 Answers
SOURCE: Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
Posted on Nov 27, 2005
GARYDALE
  • 15 Answers
SOURCE: Amp makes subs pop
It sounds like your amp chip has gone bad, here is some thing you can try turn on your unit then start tapping on top of with your finger not hard see if the any of the pops matches your finger taps some times when the chip starts to go out it well act like that.
Posted on Nov 06, 2006
trintek
  • 111 Answers
SOURCE: Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Posted on Nov 16, 2007
hawkwatcher
  • 67 Answers
SOURCE: stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Posted on Feb 15, 2008
  • 39 Answers
SOURCE: Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Posted on Jul 25, 2008
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
Sony Home Theatre System Turning Off
Appears that you have a bad cap in the power supply that is changing value as it heats up. Hard to find - only thing you can do is go to suspected units and replace them hoping that you got the bad one. Or just wait till it finally pops.
Apr 02, 2017 | Sony Home Theater: DAV-DZ870W ALL REGION...
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
Can i watch tv and use my home theatre for sound
YES !! BUT the sound wont be in 5.1 , most likely it will be stereo or mono thru all 5 speaker system , thanks AJ
Nov 19, 2009 | Audio Players & Recorders
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Can't hear the voices on my home samsung HT-X70 home theatre system
u stoip movie start it use prologic make sure center speaker pluged in ect
Oct 08, 2008 | Audio Players & Recorders
Rca 2600 home theatre
sounds like a component is getting hot. It probably needs to be looked at.
Jan 14, 2008 | RCA RT2350 System
32 people viewed this question
 Grubhead
Grubhead
