Question about Bose Wave Music System CD Shelf System
Wave radio comes on randomly
Radio comes on at various times, tonight it was at 2:30 am. I turned it off with my remoter
    Problem Solver:
  • 9 Answers
Random is truly a difficult problem to solve, if no pattern of failure can be detected. It sounds as though the alarm may be at fault. Is the alarm on and set to radio, CD, or beep? If radio, that could pinpoint the problem. If you have another, mechanical alarm, use it for a couple nights with the Bose Wave alarm off. If the Bose still acts up, then it isn't the alarm. Try unplugging the unit, waiting at least 30 seconds, and plugging it back in, which will cause you to need to reset the alarm. Alternately, remove the Bose cover and blow out dust. I find the Bose susceptible to dust as a cause of malfunction, which may point to the cause being the compact design of the unit. Good luck.
Posted on Jan 29, 2014
  • 120 Answers
SOURCE: bose wave radio signal fades in and out, cd stops and starts
i would check the power supply for bad solder joints or cracks in the traces on the printed circuit board, possible around the heaviest components (usually a transformer) or a loose connector.You can use the eraser end of a pencil to push on components to see if any of them cause the problem to manifest, and if so, turn off the power and reheat the solder connections to that component.
Posted on Jan 10, 2009
sodeep
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
Cytherian
  • 124 Answers
SOURCE: lost remote
This varies depending upon the universal remote. Some will officially support a specific range of brands and electronics. You enter in the code of the electronic device and then the remote fully controls it.
There may also be some higher end remotes that are more sophisticated that can generate test signals to aid in figuring out what signals the electronic component responds to.
You may also be able to buy a used Bose remote off a place like eBay, if you can't find a universal remote the specifically supports Bose.
Posted on Apr 14, 2010
dunnbiker
  • 8546 Answers
SOURCE: my bowes wave radio simply turns itself on in the
Find the manual and UN-set the Alarm function.
Posted on Aug 05, 2010
  • 4 Answers
SOURCE: Need help changing batteries on Wave Radio remote
Setting up the remote control
WARNING: Keep the remote control battery away from children. It may cause a fire or
chemical burn if mishandled. Do not recharge, disassemble, heat above 100°C (212°F), or
incinerate. Dispose of used battery promptly. Replace only with a battery of the correct type
and model number.
Your remote control may be one of two types. Each is identified by the way
the battery compartment unlocks to install or replace the battery.
1. Place the remote control face down on a flat surface.
2. If your remote has a slot on the back, follow step A. Otherwise, follow step B:
A. Insert the tip of a ballpoint pen into the slot. Push to the side as shown and hold. Slide
the battery compartment open with your finger.
B. Using your finger, push the tab lock to the side as shown and hold. Slide the battery
compartment open.
Setting Up
See operating
instructions for types of
battery to be used
Note: Use only a Duracell, Eveready, Maxell, or Toshiba CR2032 or DL2032 lithium battery
(available at electronics stores). If you have difficulty finding a replacement battery, contact
Bose® Product Support (see phone numbers on the inside back cover).
3. Keeping the remote control face down, insert the new battery into the compartment with
the + symbol facing up.
4. Gently slide the battery compartment closed. It locks automatically.
5. Use the supplied mounting strip if you want to attach the remote to a surface in your
listening room. Peel off the protective backing to stick one piece to the back of the remote
and the other to the selected surface.
Posted on Nov 04, 2010
I have a broken remote for wave radio...can it be replaced? How much?
go to Bose.com and put support and identify your wave radio and then you look at the parts that you buy for it.
Aug 08, 2011 | Bose Wave Radio
Our bose radio which is only one week old will not turn on tonight. We have check everything but still no radio
Call Tech Support at 877-210-3782. I was having a problem with my 14 year old Wave radio and the customer support rep was very helpful.
May 12, 2011 | Bose Wave Radio
How do I turn radio on? Is there an old-fashioned "on/off" button? The battery in the remote needs to be replaced but in the meantime,is there a way to turn the radio on?!?!?! Many thanks!
If you have new generation of Bose wave radio with no buttons on the top, it would be no other way, but with remote. Need to know the model number.
Dec 07, 2010 | Bose Wave Radio
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Remote does not work, battery is good. Can I program my dish network remote? If so what codes can I use.
Sorry to hear about your original remote; we would be happy to help you with addressing your DISH remote to your Bose Wave Radio. Here is a list of some of the codes that we havefor Bose Wave Radio: 761, 664, 656, and 639.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Bose Wave Radio provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Bose Wave Radio. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 21, 2010 | Bose Wave Radio II
I can't seem to adjust the time using the remote
You can obtain the Bose Wave radio instruction manual in electronic form, here: http://products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
See page 15 for setting the time. You should be able to do it with the unit controls.
Apr 13, 2010 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
Remote
I changed the battery in my remote, and it works fine.
Oct 22, 2008 | Bose Wave Radio
Bose Wave Music System CD Shelf System Logo
201 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
