Question about Tablets & eReaders
Dorf tap parts
Loose connection on Dorf mixer kitchen how do we fix it
Zte tablet model k88 wont connect to wifi
Weak wifi signal or defective tablet or router.
Jun 27, 2017 | Tablets & eReaders
Our new kindle paper white will not connect to our wifi
The Kindle Paperwhite automatically scans for Wi-Fi networks that are in range of your device. If one networks are found, the device will connect automatically. If a password is required, a screen appears asking you to input that information. Generally, the process is quick and easy.
Occasionally, however, you may need to connect to the Wi-Fi network manually. Follow these steps:
  1. Tap Menu?Settings.
  2. If the network to which you want to connect appears in the list, tap that network.You're finished!
  3. If the network to which you want to connect doesn't appear in the list:
    1. Tap Other.A dialog box named Enter Wi-Fi Network appears, along with the on-screen keyboard.
    2. Using the onscreen keyboard, enter the network name and, if applicable, the password.
    3. Tap the Advanced button.
    4. Work through the series of screens, entering information related to the network, including connection type, IP address, and security type.
      Advance through the screens by using the up and down arrows.
      If necessary, contact the person who set up the network for assistance with filling in this information.
    5. When all the necessary information has been entered, tap the Connect button to join the network.
If your Kindle Paperwhite is connected to your home network but can't connect to Amazon, you may need to reestablish the connection. Tap Menu?Settings?Wi-Fi Networks, and then tap the network that has a check mark to its left. When the Forget Network? dialog box appears, tap Forget. You'll have to reselect the network and enter the password (if one is required).
If you're having trouble connecting to your home network, unplug the Wi-Fi router, wait at least 60 seconds, and then plug it in and wait for the network to restart.
If this does not work....follow this link and do a factory reset.
http://www.wikihow.com/Reset-a-Kindle
Good luck.
Semper Fi,
DrZ
Apr 24, 2017 | Tablets & eReaders
Connect my amazon tap to the internet
To connect Amazon Tap to a Wi-Fi hotspot:
  1. Go to the settings menu on your mobile device and search for a Wi-Fi hotspot option. ...
  2. In the Alexa app, open the left navigation panel and then select Settings.
  3. Select your Amazon Tap, and then select Update Wi-Fi.
More items...
Amazon.com Help: Connect Amazon Tap to a Wi-Fi Hotspot
https://www.amazon.com/gp/help/customer/display.html?nodeId=202021980 https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=how+to+Connect+my+amazon+tap+to+the+internet
Dec 23, 2016 | Amazon Tablets & eReaders
How do I set up alexa amazon tap Bluetooth?
Connect Amazon Tap to a Wi-Fi network. Follow the instructions in the app to connect Amazon Tap to a Wi-Fi network. If the setup process does not automatically start, press and hold the Wi-Fi / Bluetooth button on Amazon Tap for five seconds. Then, open the Alexa app, and go to Settings > Set up a new device.
Amazon.com Help: Set Up Your Amazon Tap
https://www.amazon.com/gp/help/customer/display.html?nodeId=202014730 set up alexa amazon tap Bluetooth Google Search
Dec 04, 2016 | Amazon Tablets & eReaders
Undefined
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
Zeepad jelly bean
when i tap on the "K" or "E" keys - they do not type. Is there something wrong with the tablet os is this something I can fix?
Jan 10, 2014 | Tablets & eReaders
My wireless connection is disabled how do I correct
  1. Swipe down from the top of the screen to show Quick Settings, and then tap Wireless.
  2. Verify that Airplane Mode is Off.
  3. Next to Wi-Fi, tap On.
  4. Tap a network to connect to it. If you see a lock icon, a network password is required. Enter the Wi-Fi network password, and then tap Connect.Note: If you don't know the password, check with the person who set up the network. This password is not your Amazon account password.
After you connect to a Wi-Fi network, your Kindle Fire automatically connects to the network again when it's in range. If more than one network is in range, your Kindle Fire automatically connects to the last network used.
[Source]
Nov 01, 2013 | Amazon Kindle Fire HD
7 cyberpad tabletpc by iview how you get connect to internet
You can go ti Wi Fi from Settings, but the quickest way is to click in the icon in the front page where you control volume; light etcetera... Tap the one in the left corner once and wait until is fully bright. It should display a "?" in the lower part of your screen. This will indicate to sing in to Wi Fi. Tap this and then the browser you want to use to sing in.
Jun 30, 2013 | Tablets & eReaders
Mac address of Dell Streak
Steve,
Below are steps to get the mac address on your Dell Streak.
From the home screen:
  1. Tap the Menu key
  2. Tap 'Settings'
  3. Scroll down and tap 'About Device'
  4. Tap 'Status'
The MAC is listed under 'Wi-Fi MAC Address'
How to find the IP address on your Streak:
  1. Tap the Menu key
  2. Tap 'Settings'
  3. Tap 'Wireless Controls'
  4. Tap 'Wi-Fi Settings'
At the bottom, under 'Wi-Fi Networks', tap the connection you are connected to and the IP address will be displayed on the next screen
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jun 13, 2013 | Dell Streak 7 WiFi Tablet
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
