Question about Lincoln Electric Electrical Supplies
Kubota zd28 keeps blowing control system fuse
I need a wiring diagram for a Kubota B7800,current to fuel solenoid keep dropping off.
Would check ignition switch, maybe you can just spray liberally with electric contact cleaner in every opening you can find and then blow out with compressed air before it dries.
Sep 06, 2017 | Kubota Garden
I just replace hydr. pump on a bx2200 Kubota tractor but it keeps blowing the filters apart . can you help me ?
connected the pipes to the pump incorrectly
filters go on the return lines or suction lines not the high pressure side of the pump
they are only good for a pressure of 30psi not 2000psi
Sep 02, 2017 | Kubota Garden
Kubota zd28 mower was running fine put away but now PTO wont engage.
if your saying that pto wont do anything , that's either an electrical short or a broken belt , in rare cases the clutches go too , now if your saying the pto engauges and stalls the engine or makes horrible noises , then that's a bearing , im betting the deck shaft bearings are in need of some serious grease work
Mar 04, 2017 | Kubota Garden
2006 Buick Rendezvous 10 Amp ABS fuse keeps blowing. What could be the problem?
There is a shot to ground in the ABS system ! If familiar with electrical trouble shoot , find a wiring diagram an test the B+ power circuit ! That fuse supply's power to the electronic brake control module , if no short on wire from fuse box to brake control module , the module has an internal problem .
Jul 26, 2016 | 2006 Buick Rendezvous
Need the front deck wheel and swivel for zd28 60 inch deck
Marvin, check the links below for Kubota deck parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Parts Discount Online Parts Cheap affordable lawnmower parts
http://www.tractorjoe.com/kubota
kubotaParts Online
Kubota Tractor Corporation Parts
Apr 22, 2016 | Garden
What causes#37 fuse to keep blowing on 2004 chrysler pacifica
The fuse goes to the auto shutdown relay from there it goes to two powertrain control modules. Test the relay or replace or there is a short in the system
Oct 04, 2014 | 2004 Chrysler Pacifica
Starter stays engaged or blows a fuse when I try to start my skid steer
This could be the starter or the ignition switch, Take the starter out and have it tested. IF the starter tests ok, replace the ignition switch.
Jan 06, 2014 | Cars & Trucks
04 chevy colorado #21 fuse keeps blowing
your going to have to remove the inner door panel and liner to look for frayed wire(s) also may have to look at the wires running in the boot that runs between the door and frame.
Jun 02, 2013 | Chevrolet Cars & Trucks
Can not shut off engine gr2100 kubota
i have one of those theres a fuse under the hood blowed i think theres 3 and its the middle one
Jul 14, 2012 | Garden
Why does fuse # 25 keep blowing out on my Chrysler pacifica 2004
Fuses pop because it is breaking the direct line of voltage that is being selected...anotherwords...instead of when you turn on your radio and the incorrect amount of voltage that is being sent to the radio frys it, the fuse breaks/pops to stop the flow of voltage to the radio.
The problem seems to either be a bad relay or wires are touching somewhere in that system.
Nov 20, 2011 | 2004 Chrysler Pacifica
Electrical Supplies Logo
Top Lincoln Electric Electrical Supplies Experts
Tim Venetis
Bill Boyd
joe_jochoa
Level 1 Expert
Are you a Lincoln Electric Electrical Supply Expert? Answer questions, earn points and help others
