Question about Magix Music Studio 2005 Deluxe for PC
Cd will not burn in magix get write error (sk/asc/ascq03/dc/08)
Wont burn cd keep putting this up write error (sk/asc/ascq03/dc/08)
Click on "Burn CD" in AC Cleanig lab and error
The problem may lie on windows or the software itself
1. try to create a test file and try burning it to a disk 2. To do this Create a test file right Click on it > Click on send to DVD> 3. Keep on hitting next If the was successful in burning the test file using the software this means Windows built in burning software is up and running 4. We need uninstall /reinstall the software 5. Else you need to Click on Start > Run > Type Services.msc > Scroll Down look for Imapi CD Burning double click on it
6. Click on Automatic on the dropdown and click on start
Restart the computer
Hope this helps
Jun 04, 2011 | Magix Audio Cleaning Lab 12 Full Version...
Error burning iso file on Roxio Creator Basic ver 9.0.117
I found that burning images with roxio can be a bummer, plus it is slow. Here is a free program that works great:
http://www.imgburn.com/index.php?act=download
Aug 03, 2009 | Roxio Easy CD & DVD Burning
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Need actavation code for music makers 12 deluxe.
I had this Problem, i don't know if this will help but it did with me, but i can still only put one song on a CD.
You go onto File
Then Export Arrangement
Click on Burn Audio CD
When I Installed this programme it came with a Magix Music Editor 2.0, if this programme comes up then you look under File and theres a little picture of a peice of paper, a folder ect... keep going along untill you reach a little picture of a CD (fourth from the end of the row), then click on that and it comes up with a box that you can name your CD and you can just click burn CD.
Im sorry if this is totaly of subject and you dont actually need this information, but just incase i thought i would mention it :) xxx
Mar 18, 2009 | Magix Music Maker 12 Deluxe
Moving MAGIX files to a different computer.
If magix support .iso files do an iso image of the cd you plan to burn
you'll have then a 600-700mb iso file that you have to burn at work.
of course at work your recording program should support ISO's, or you will obtain the same unusable file as you get back from your home
Nov 21, 2008 | Magix Audio Cleaning Lab 2005 for PC
Cannot get magix movies to burn to my usb burner
u burn your movie is old software so he is not burn in your usb / DVD / CD or other deivce. u purchase magix muvies burner software or go to this site: http://www.supermediastore.com/ and download your software and enjoy
Jul 27, 2008 | Computers & Internet
The burning process failed by internal error while processing my Magix photostory on CD & DVD 4.0
hmmm...what kind of pc you running, and how much memory, cpu speed you got in that box?
May 04, 2008 | Computers & Internet
AW-G170A
the only way to get rid off this problem is "throw your dvd-r/w in street garbage collector can". :-)
Oct 01, 2007 | Computers & Internet
NEC-3520A Suddenly stop to burn correctly, but reads OK
Have you tried lowering the burn/erase speed? To begin, simply do what you need to do on the lowest speed, and then keep increasing until it gives the error again. This will most likely work. I had this problem and I burn now CDs at 16x.
Jun 11, 2007 | NEC (ND-3520A-KIT-BLU) Burner
Magix Music Studio 2005 Deluxe for PC Logo
15 people viewed this question
Top Magix Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
