Question about Samsung LN-T3753H TV
Sound but no picture
Turns on but no picture and no menus or volume icons
HOW DO I GET SOUND
At the top of your keyboard you have some icons with pictures of some speakers. One shows 3 curves coming out of the speaker which signifies the loudest sound, another shows a speaker with just one curve in front of it which signifies low sound, and the 3rd speaker has an X on it which signifies no sound. Click on the speaker with the most curves to control the volume. Also, at the bottom of your monitor you have a picture of a speaker with curves in front of it. Click on that icon, and you will see how much sound you have. To make the sound louder, click on the bar with your mouse and raise it up to increase your sound. It should also tell you the percentage of the sound that you will hear. To lower the volume, click on the bar and lower it.
Mar 10, 2015 | Computers & Internet
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
I have an LG 37LG50 that turns on, and so does the bulb/lamp but there's not picture or sound. Menus don't show either.
the main board is the usual cause of those symptoms. You should be able to get a replacement main board by contacting the guys at www.tvcircuitboards.com
Jul 08, 2012 | LG 37LG50 37 in. LCD HDTV
Acertravelmate4000 got it used,don,t know how to turn off mute,turn on or up volume
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Jan 12, 2010 | Acer Computers & Internet
My computer will no longer play music or any kind of noise
Check that your speakers are plugged into the right jack either in your sound card or the sound panel on the motherboard. If no sound then try plugging speakers into another computer and see if they are working and have power. Go to "control panel" and click on "Sound and Audio Devices" and under the volume tab under Device Volume make sure that the "Mute" box isn't checked. Also check the "place Volume icon in the taskbar" box if it isn't already checked. Go to the Volume control on the task bar and check out the audio volume levels and make sure they're not turned all the way off. Also under "Sound and Audio Devices" underl Volume tab click on "Advanced" and make sure that you have selected the proper kind of speakers in the speaker setup box.
YOu didn't say so, so I'm assuming that you're using Windows XP. If you're not the menus may be a little different but similar.
Sep 29, 2009 | Microsoft Windows XP Home Edition
Sound to compputer headphones stopped working
go to main screen panel, then go to speaker icon, right click, go to properties, make sure headphones are enabled, volume is turned up, and see if the headphones are set as default. Update drivers if necessary
Aug 27, 2009 | Audio Players & Recorders
Volume is too low
go to sound icon in bottom right corner, click on mixer, then there is a sound output screen. I had the same problem on my laptop until i found this screen and turns out my laptop was using 20% of its volume!
Jun 15, 2009 | Acer Aspire 7520-5757 Notebook
Volume auto turns down
hi i downloaded windows 7 and now my touch volume control does not work what should i do
May 28, 2009 | Computers & Internet
TV turns off-on when I try to adjust the volume
check tact switchs ALL on the control panal. several with leaky switchs.good luck wayne
Oct 22, 2006 | Sony KP-53V90 53" Rear Projection...
Samsung LN-T3753H TV Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
