Question about Fisher and Paykel GWL11 Top Load Washer
F&P EcoSmart-Circuit board problems
When you hit the start buttons, it just starts beeping. It worked fine and then the other day just started doing this. The lights stay on a few seconds after unplugging it. Then when you plug it back in and hit start again, it just does the same thing. Is there anything I can do myself to fix this problem, or am I going to have to get a new circuit board?
  • On the cape Nov 19, 2007
    I have the same problem. I just replaced the computer, did two loads but now it won't work again. Can somebody help? This machine was too expensive to just throw out the door after 7 years!
  • 69 Answers
Probably the lid switch is faulty
Posted on Sep 23, 2007
SOURCE:
Part of treadmill buttons won't work?
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Aug 20, 2016 | HEALTHRIDER T650I Treadmill Front Roller...
I have a double drawer fisher and paykel DCS dd-224p model. bottom drawer works fine. top not working
These units are nothing but grief!! Problem sounds similar to my one, it caused me no end of problems from the time it was installed and don\'t bother calling F&P service coz it will cost you almost as much as a new dishwasher. They have an inherent prob with circuit board, even service tech (on the quiet) said they are bad.The best thing I did for mine was throw it on the scrap metal pile and bought myself a Meile, not one problem. its super quiet and designed to last 20 years. Use the bottom one till it completely craps itself (prob not long) and then buy a NON F&P one!!!
Dec 20, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Washer won't drain and some cycles won't work
Make sure your drain hose is at least 2ft off the ground if your drain pipe is to low it wont drain
Feb 18, 2010 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel EcoSmart GWL15 Machine won't agitate or spin - two yellow lights come on, and machine beeps every second or so. This happens even with the power off.
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 12, 2009 | Fisher Paykel EcoSmart GWL15
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Mar 01, 2009 | Whirlpool GEW9250 Electric Dryer
My frigidaire gas range oven won't work
Hello Welcome,
If you get a F1 this means Circuit board is defective.
And you need to Check or replace: the control board.
This is a job for service to be sure before you buy the control board!
Thank You Huuum.
Please remember to leave a solved rating before you sign off!
May 21, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
Random beeping and panel buttons not working
There may be a failure of some type in the system processor area.
Maybe some of the steam from the bioling water and oil and water from the cooking got inside on to the circuit board, and caused some damage.
It is also possible that the heat from the stove did some damage.
It is also possible that there was simply a failure in the system processor area.
Jerry G.
Apr 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Lots of beeps
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 19, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
105 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
