Question about Car Audio & Video
Ute wireing How to run my wires from inside my ute to the back it's a holden storm 02 model
    New Friend:
Fd 600a m043892
Posted on Jul 14, 2013
5 Suggested Answers
  • 53 Answers
SOURCE: Need code for stereo in 2005 Mitsubishi Triton Ute.
The only way to retrieve a code would be by calling clarion tech support, but they will ask for the purchase ticket to verify that you did buy it legit.
Posted on Jul 14, 2009
  • 4930 Answers
SOURCE: what is the radio code for 1996 xh ford falcon ute
The radio SERIAL NUMBER will have to be quoted in order to calculate a code.
This normally begins with M????? or L or C or V
This is found on a label on the radio casing
Posted on Sep 12, 2009
Boole5555
  • 160 Answers
SOURCE: holden stereo wiring diagrams 98 holden vectra
Try,
the12volt.com
Posted on Jan 05, 2010
  • 4930 Answers
SOURCE: how do I remove the radio in a 85 model ford
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here is a video showing how to remove a standard radio from the dashboard.
A pair of extractors are required (available from Ebay , etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys
or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4
securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These
can be unscrewed using the appropriate size of Allen key
Posted on May 22, 2010
HOW TO REMOVE A HAND BRAKE CABLE ON A WB HOLDEN UTE
find a holden hx hz wb manual or go to a library and photo copy the pages needed or look at the link below if you can do it on your own.
Replacing handbrake cable
May 05, 2016 | 1973 Holden Ute
Need a wiring diagram 4 stereo 4 a 2003 holden jackaroo
no you don't need it.
you can use an aeropro wiring harness adapter for your car and then an adapter for the make of stereo you are wanting to install..
http://www.supercheapauto.com.au/online-store/products/Aerpro-Wiring-Harness-APP062.aspx?pid=11542#Recommendations
https://www.autobarn.com.au/aerpro-iso-connector-holden-vt-vx-vu-ute-app062
check with the store to confirm which ones you need for your car and stereo
Sep 17, 2015 | Holden Cars & Trucks
Where can I buy weather strips to suit VY Holden commodore ute 2003
You will be able to purchase the weather strips for your ute from your local holden dealer.
You would also be able to place and order through one of your local aftermarket retails .
Repco , Burson, Rear Spares ,Auto Pro
Feb 16, 2015 | Holden Cars & Trucks
I am looking for a die-cast model larger than scale of 1:43 of a Holden FC Utility (Ute) anywhere in the world please
Look up some of the early year Holden forums on the net that cover the the FE and FCs and others around that era. Join up and ask if someone has one of these FC cast models for sale. You are much more likely to be successful and if not someone may be able to give you a lead to follow up. You will be very lucky to find an FC Ute model though.
Dec 13, 2014 | Holden Cars & Trucks
Does this work for you?
http://www.ebay.com.au/itm/1-43-ARMCO-MODEL-CARS-HOLDEN-FC-UTE-UTILITY-BLACK-LTD-EDITION-OF-JUST-250-/361089036932?
Dec 13, 2014 | Crafts & Hobbies
How do you remove the Holden VE clutch fluid restrictor for faster gear changes ?
Is that really Holden\'s fix for synchro? Go online to an owners forum and see what they say. Its a new one on me. Google Holden SSV synchro and see what pops up?
Oct 20, 2014 | 2007 Holden Ute SV6
Holden colorado RG 2014 lx speaker diagram
RED IS POWER
BLACK GROUND
YELLOW LIGHT POWER
BLUE ANTENNA POWER
THE REST, GET A (AA OR AAA) BATTERY, AND TOUNCH THE POLARITIES TOGHETER WITH THE REST OF THE WIRES, YOU WELL HEAR THE DISIGNATED SPEAKER MAKE NOISE.
May 23, 2014 | 2007 Holden Ute SV6
Reverse lights turn off when brake is applied
This would normally mean a loose earth wire to the light , but check the bulbs as well as a bulb with one filament gone can short or earth back through another circuit You can jump a small wire from the chassis to the light assembly body to check
May 16, 2010 | 1994 Toyota Camry
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
