Hp 430 wifi key some time not working properly.
Hp 430 The Caps Lock button is flashing and the wifi connection button's light is
remove the battery for a moment and re-install again, it will solve the issue
Feb 04, 2013 | Computers & Internet
No video on HP S3421P video. verified monitor is working. is there a replacment?
it would be premature to replace a video card, when it has not been tested to be faulty.
Please take the computer to a local professional so the machine can be properly inspected.
THIS WILL SAVE YOU TIME AND MONEY, you do not want to replace parts that are not faulty.
Jan 18, 2013 | HEWLETT-PACKARD Pavilion Slimline S3421P...
When try to print in my hp 430 ,paper is not moving properly and tear the paper badly.
Try to clean it's dragging system (rubber roll) using some adhesive tape.
Sep 17, 2012 | HP DesignJet 430 InkJet Printer
Will not connect to wifi
Check your wifi settings in the computer to make sure the wifi is turned on and that the security key, WEP or WPS key, are the same in the computer and the router if you have security enabled. If you have an HP computer and a CISCO router try using a different WiFi channel, the router should have 10 channel options if it is a Cisco router and the default channel doesn't always work with HP computers.
Dec 26, 2011 | Computers & Internet
How do you turn the wifi on
Usually some laptops have dedicated key to turn on Wifi / blue tooth. and some should be turned on using the fn ( function key) which can be located near to the alt key and the wifi symbol key ( on the number keys) simultaneously.
Before that ensure that the driver software which came along with your computer is installed properly. because trying to switch on the wifi without installing proper wifi hardware drivers wont help at all.
I hope this is helpful to you
Thanks
Sep 22, 2010 | HP Nx6310 Notebook
MY designjet 430 all of a sudden is not printing straight, but is printing wiggly lines. Any ides on how to fix this?
You can try Print-Quality Plot test to diagnose the problem. Load paper, when ready light up, then press Form Feed and Media Source keys together. After print is done, unload paper.
This plot consists six tests. The third one is Vertical Line Straightness (VLS) test. You can read the HP 430 Service Manual page 6-7, 6-8 and 6-9. These articles will tell you how to correect the problem.
Sep 01, 2010 | HP DesignJet 430 InkJet Printer
I can´t turn on wireless on my HP Pavillion dv9000.what I should to do to turn it on?
Is this working well before? Do you think your wireless adapter is installed and is working properly?
If it is so, then just turn ON your wifi radio receiver by holding down the FN key on your keyboard and pressing a corresponding FUNCTION Key. Look for the function key (F1 to F12) with the wifi radio wave icon on it like ))) or ((( ))). Example, if F10 has that wifi icon, then hold down FN and press F10 to turn your wifi ON or OFF.
Jun 04, 2010 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
