Printer password I need to reset the IP address on this printer, but i need a 8 digit password to get onto the interface. Anyone know it?
    Problem Solver:
  • 11 Answers
What brand and model is the printer?
Posted on Jul 09, 2013
Testimonial: "Cant believe i didnt even put it. It's a HP 4250n (laserjet). I've google'd it with no luck, and tried anything generic that comes to mind."
SOURCE: Sharp AR-BC320 NIC Default Login & Password
Login: admin
Pass: Sharp
Posted on Nov 22, 2008
SOURCE: Reset Dell 1720dn network address to get back access to it?
Please have a look if you have Dell 1700 series laser printer. Please follow the instruction bellow to reset printer to factory default: 1. Power Off the Printer from the back switch from the back 2. Open Front cover 3. Hold Down “Continue” & “Cancel” button while turning printer on
se http://digg.com/hardware/How_to_Reset_Dell_1700_1700dn_1710_1710dn_1720_1720
Regards Anders.Thornberg.Qnetcom.se
Posted on Dec 29, 2008
  • 54 Answers
SOURCE: change my printer network access password
For an HP Officejet printer:
You can reset the printer definitions taking off the power cord and holding # + 6 buttons (semicomplete reset) or # + 9 (full reset) while connecting power cord again.
For an HP Laserjet printer:
Try logging in with admin as username and leave the password blank.
If not, preform a "cold reset" on the printer which resets parameters back to factory defaults. You want to print off a configuration page first. From the service manual :-
Cold Reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
Use the following procedure to perform a cold reset.
1. Turn off the printer.
2. Press and hold the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the Go button.
NOTE If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Posted on Apr 09, 2009
SOURCE: Factory Reset
Remove printer drivers
Printer off.
Disconnect LAN.
Open front cover.
Hold/press both buttons on front, keep holding.
Turn on at back.
Only release button when all lights have stopped flashing, top and bottom light illuminated.
Close front cover
Connect LAN cable.
Reinstall via add network printer - will detect and reset new IP.
Posted on Apr 30, 2009
SOURCE: My printer ( Lexmark E260DN
instroll this printer in my computer because i have not software this printer
Posted on Sep 09, 2010
Want to change the password on a konica c235 copier
Accessing "Copiers" (or printers/scanners/etc for that matter) is generally done through a WEB interface.
USUALLY you can access the "copiers" web-interface by entering it's IP address into your web-browser.
An example.. (regardless of browser..internet explorer, firefox, chrome, safari, etc)
You can type: 192.168.1.(***) Where "(***)" is the IP address of the printer.
Often the printer will have some buttons (menu/settings/etc)... which will show your the IP address of the printer (mind you those "***"'s ..is a number from 0 to 255...no smaller, no greater).
And..you IP might not be 192.168.1.*** To check that.. (windows)... Start->run->CMD
at the prompt.. type IPCONFIG
And look at your own IP address.. it might be 192.168.1.22 (I picked 22 randomly).. it might be 192.168.0.22 (Again, 22 randomly, but notice the 3rd number was 0)..
As long as you have those first 3 numbers... 192.168.(we'll say 1).1.***
Your printer LIVES on 0-255 of the last 4 digits..
You can probably find that number on the printers screen, but if you can't.. you can go through 256 tries (192.168.1.0...192.168.1.1...192.168.1.255)... to find it..
Once you see it.. you'll need to login... try "admin/admin" for name/pw and "admin/password" .. if that doesn't work, look under the printer to see if it has a sticker for its name/password for administrator.
If none of that works..write me back.
Oct 19, 2012 | Konica Minolta BZ-C253
Need to install ir 5020 onto server. Do I need any config software first like HP JetDirect?
You would need to ensure that the IR 5020 has a valid IP address (Should be located on the Network Configuration Menu from the on-screen display). When plugged into the network for the first time the printer is usually given an IP address, this would allow you to connect to the web management interface and make changes to the settings from an easier interface than the on-screen display.
If you are planning on sharing the IR 5020 out from the server to other computers then you would then need to assign a static IP address to the IR 5020 so that the IP address would not change once configured.
(Side-note - I do not recommend using DHCP on printers as it can cause issues down the road if the printer is given a defferent IP address by the DHCP server.)
Sep 13, 2011 | Canon imageRUNNER 5020 Copier
My printer won't print any document since the day that i accidentally unplugged the socket while i'm printing.. need your help. i've got so much to print.. thanks..
Open Printers folder from Control panel.
Open the priter you are printing to and see if there are any documents on queue. Delete all of them (Printer/Cancel all documents). Then close the printer's windows and look the status of the printer. If it is "Offline", right click it and choose "Use Printer Online". If the status is "Paused", right click it and choose "Resume printing".
Aug 08, 2010 | Office Equipment & Supplies
I need to add IBM Infoprint 1116 to my home network using IP address. How can I change already setted IP and gatway addresses on it to needed?
If you know ip address of printer then you can access your printer with web interface for that type your printer ip address in internet explorer address bar.
then you can access configuration of printer.
But if you don't know ip then you need to check network configuration menu of printer .
For that press menu button of printer then enter in network settings then you can know the printer ip address.
Let me know if you need further assistance.
Thanks for using FixYa.
May 20, 2010 | IBM Infoprint 1116 Laser Printer
Restraunt Pro Express problems
Option 1 (Ethernet II only): Using a web browser, type the default IP address (found on a label on the interface card) into the address field of your web browser. The configuration screen should appear. The default password for the interface is Epson. We highly recommend this be changed. Once the web interface is running, all application, network, printer and password settings can be modified.
from: http://www.beaglehardware.com/howtoethernet.html
Jun 24, 2009 | Pc America Restaurant Pro Express
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Jun 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can't connect Canon Pixma MX310 to wireless network!
This printer does not have a network interface. There is no ip address for this printer. You must connect via usb.
Jan 21, 2009 | Canon PIXMA MX310 All-In-One Printer
I need to change the IP address on my hp color laser jet 2840 coud you help me with that
Most HP printers can be reset to factory defaults (or cold-reset ) by turning the printer off and holding down the Online or Go button while turning the printer back on. The printer control panel display should read "Cold Reset" or "Restoring Factory Settings" or something like these lines. This will remove any IP address that the printer had previously.
When you plug it in, your router should have assigned an ip address automatically. Go into your router and look at the attached devices and it will show you what ip address has been assigned to each device on your network.
Use Web Interface or Manually Assign an IP address NOTE: Network HP Printers allow you to manage them via Internet Explorer. You can enter the IP address that the printer currently has and access its configuration settings. This assumes that the web interface hasn't been locked.
NOTE: We recommend that you install the latest version of Sun's Java software before trying these steps. See this How To: How to Update Sun's Java 2 Runtime Environment Plug-in.
  1. Print the Configuration page if needed. You will be entering the "current" IP Address.
  2. Open Internet Explorer. Delete EVERYTHING from the Address line.
  3. Enter the IP Address in the Address line and press Enter.
  4. You should then connect to the printer. If this fail, go to the next section to assign the IP address manually.
    NOTE: There are 2 basics versions of the web interface. Type 1 is on newer printers. Type 2 is on older models
  5. Type 1: Click the Networking tab.
    Type 2: Click the Administration button. Click the Configuration tab.
  6. Edit the IP address, Subnet Mask, and Gateway as needed.
  7. Do not change any other fields.
  8. Scroll to the bottom and click Apply. Click OK.
  9. Close Internet Explorer.
  10. Restart the Printer. Print the Configuration page to see if number was set.
NOTE: If the above steps do not allow you to assign the IP address via the Wizard, you will need to do it through at the printer itself.
  1. Go to this HP Support Page.
    Configuring TCP/IP through the Front Control Panel
  2. Click the link to your printer model. Highlight these steps.
  3. From the File menu choose Print. In the Page Range section, click Selection. Click Print.
    Note: For the complete printer user guide, go to the HP Printers Support & Troubleshooting page. Locate your specific printer type and model. On its home page, under self-help resources, click the manuals link. Download the printer's User Guide (not the Getting Started Guide). Look for steps to manually configure TCP/IP parameters from the printer control panel.
  4. Follow the steps from the printout to assign the desired IP Address to the printer.
    IP address will be entered at the IP BYTE prompt
    Subnet mask is entered at SM BYTE prompt
    Gateway address is entered at GW BYTE prompt
    Note: The syslog server IP address (LG BYTE 1=) and timeout (TIMEOUT=) do not need configured.
  5. Once the IP Address is entered, restart the Printer. Print the Configuration page to see if number was set.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | HP LaserJet 2840 Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
44 people viewed this question
jasbo
jasbo
