Question about Cycling
My crank and back rim are broken - Cycling
But a new probaly would cost too much to repair
Posted on Jul 11, 2013
How do I fix a broken front rim?
you can get rims rerolled you need to google rim repairers and they will advise you wether it can be repaired or rerolled but for safety I would ad vise you to purchase a new rim
Dec 10, 2014 | 2013 Ducati Monster 796
Why is my bike broken
Most likely the problem is the bearing in the rear wheel. Your best solution is to find a different rear wheel as replacing the one there will be difficult if you don't have the sprocket removal tool. 7_16_2013_10_14_46_pm.jpg
Jul 09, 2013 | Crafts & Hobbies
I need a replacement rear wheel rim for my Edgewood lx hybrid
you didn't specify why you need a new wheel, is it just out of true, is it broken, is it bent?
If the wheel just needs to be trued this is an easy fix for most mechanics. You can even do it yourself using the brake pads as a guide. If a spoke is broken, this can be easily replaced and retrued. If the rim is actually bent or broken, then the rim should be replaced.
Rims can be replaced but they require a good mechanic that has the skill to relace the wheel, true it and tension it properly and at a minimum a decent mechanic with these skills will charge $25-50 for the labor. Assuming that the mechanic can get the exact same rim you are looking at about $20-50 for the rim. If that particular rim is not available then they can get something similar but it will most likely require a new set of spokes because rims are different thicknesses. Most shops charge $1-3 per spoke times 32 or 36 spokes for a typical wheel.
The easiest fix is to just buy a prebuilt wheel, these will typically run about $25-65+ for a complete wheel (not including tire, tube and rimstrip).
Your local bike shop/Diamondback Raleigh dealer will be able to help you determine what is best for your situation.
Jan 31, 2013 | Diamondback Edgewood LX 700c Men's Hybrid...
My bosh classic xx 1400 express washing machine door has came off. is there any way of getting it back on ? thanks wendy
you can buy a new rim easy to fit is it the inner or the outer rim check before you buy ???? you will need the enr no
Jun 24, 2012 | Bosch Exxcel WFX 145S Front Load Washer
Broken spokes on rear wheel
It is not that hard to replace a few broken shokes. All you have to do is take the rim off the bike and take the tire off of the rim. Install the new spokes and tighted them to the specs and put everything back on the bike and take it for a ride. After riding, I would check the spokes and retight to make sure there ready for your next ride.
May 07, 2010 | 2000 Yamaha V Star Classic
Spare tire is stuck, will not release
The crank mechanism gets very little attention but should be lubed from time to time but few people do and then this is what happens.To get the spare off without letting it down first is tricky and dangerous if your alone but with help and by going carefully,undo the anchor from the rim by pry it down with a bar until you can get the whole thing to move at least 2" from the truick bed,at this time the cable may break so don,t lay under it.Once it has come down the 2 or so inches push the tire and rim back up to slacken the cable then feed the hanger to the inside of the rim,now at any point the rim will fall off the truck so extra hands are needed to lower it to the ground.
Nov 24, 2009 | 2000 GMC Sierra
The back rim on my 20'' bike like skips a rotation and makes a loud cracking noise when i rotate my rim and it is wobbling on the axel itself
What do you mean by "skips a rotation"? From your description about it wobbling on the axle itself, it is very likely you have a broken rear axle. If you loosen the axle nuts you will be able to tell if the axle is still in one piece. When you loosen the axle nuts be careful because if the axle is broken it may fall out along with some ball bearings.
Nov 03, 2009 | Cycling
2007 toyota tacoma pressure sensor
If your new rims do not have the transmitters installed, the light is not going to go out.
If the new rims do have the transmitters installed, and one is broken during the installation, the light will not go out. It is common for tire machines to damage the transmitters.
If the rims have the transmitters installed, and all the tires are at the proper inflation, I would check the spare tire pressure. It too is monitored.
Thnaks for choosing FixYa for assistance. Please feel free to comment back if you have any futher questions. Thanks.
Jan 19, 2009 | 2007 Toyota Tacoma
Cycling Logo
23 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
