Question about Vehicle Parts & Accessories
Atwood protector gs961lp rv low power
LP GAS DECTER
3 Suggested Answers
  • 234 Answers
SOURCE: i need a service manual for Atwood 2001 series RV LP gas detect
Call one of the motor home supplier and you will be able to get it.
Posted on Apr 01, 2009
motor1258
  • 6674 Answers
SOURCE: The LP gas detector alarm is going off and I can't stop it.
Unfortunately, it may have to be replaced. Not uncommon for those to be affected by humidity, condensation etc, hair spray, aerosols, moth balls too close, etc. and begin to malfunction. Just be sure propane is off. They can be bench tested,(out of the unit) with a battery, just to be sure it's time to replace it.
Posted on May 13, 2010
Pilot light will not stay lit. already replaced thermal coupler. 6 gallon
A thermocouple makes 30MV power by a temperature differential across the end of the thermocouple, many times people set the entire end inthe flame heating the entire end thus dropping out the power, you cannot bake them into working there must be a temperature differential from the base to tip about a 1.5 inch section. It wil not work correctly if the entire end is hot.
Otherwise the gas valve is bad.
Nov 06, 2013 | Atwood 10 Gal LP Gas /Elect. WATER HEATER
Have an Atwood Model MPD93756 lp water heater in my RV. It lights fine, but continues running until the water boils & relief valve starts leaking. Have replace the ECP thermostat assembly & Gas Valve,...
Are you 100% sure that new ECO & Thermostat were installed properly, and all surfaces where they make contact on tank are clean? If all is correct there, the thermostat should first cut out the power, then the ECO should thermostat fail. be sure you didn't mix the 2 up when installing them. ECO has higher cut out temperature. Only other thing to consider is pressure in the system may be higher than normal.
Sep 29, 2013 | RTO Atwood Water Heater - 6 Gal LP
Where can i buy 37c14u-5 gas valve
If its for an rv water heater as stated above ( Atwood) any rv dealer should stock them.
Feb 08, 2013 | RTO Atwood Water Heater - 6 Gal LP
Jan 01, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
I need a service manual for Atwood 2001 series RV LP gas detect
Mar 30, 2009 | RTO Atwood Water Heater - 6 Gal LP
Vehicle Parts & Accessories Logo
184 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
