Question about HP LaserJet Pro 200 color MFP M276nw MFC / All-In-One Color Wireless
Cold reset of m276nw - HP LaserJet Pro 200 color MFP M276nw MFC / All-In-One Color Wireless
I have just changed the toner and now everytime i print something there is 4coloured stripes on the page
sounds like either the cartridge is not seated to the contacts properly or it is defective. Try reseating the cartridge, make sure there is no shipping tape covering any of the contacts on the cartridge.
Mar 18, 2015 | HP Color LaserJet Pro 200 M276nw
Google plus
49.xxxx error is a catch all. Could be bad firmware, bad network, bad print job, etc.
Power off your PC. Power off the printer. Power on the printer then the PC. Do you have the 49 error now? If not print something, but not what you printed when you got the error. If you are still good, try printing something else. Still good, the error probably went away. If it errors again, somebody will have to look at it. Maybe upgrade the firmware or replace the formatter. How old is the printer? Is it still on warranty?
Jul 16, 2014 | HP LaserJet Pro 200 color MFP M276nw MFC /...
Where i can find the service manual for the hp lj pro 200 clr m276nw
try here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=5097654&lc=en&cc=us&dlc=en&lang=en&cc=us
Jun 12, 2014 | HP LaserJet Office Equipment & Supplies
What is the administrator password for the hp lj pro 200 clr m276nw
this may tell you but i am not sure http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=5097654&lc=en&cc=us&dlc=en&lang=en&cc=us but it does have a question box also
How do i cold reset
Cold reset
A cold reset unlocks menus that have been previously locked and resets all control panel menu items to the factory defaults. A cold reset does not clear the values in the service menu, such as the serial number and the page counts.
NOTE: Before performing a cold reset, print a menu map and a configuration page. Use the information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before performing a cold reset. Make note of the IP address that is listed on the Jetdirect configuration page. You will need to restore the IP address after performing a cold reset.
To perform a cold reset
1. Turn the MFP off and then on.
2. When the memory count appears on the control panel display, press and hold 6 until all three LEDs flash once and then stay on. This might take up to 20 seconds. wait until the machine display gives you the next option this may take upto 2 mins again
3. Press 3 four times until COLD RESET appears on the control panel display.
4. Press 6 one time. The MFP continues its initialization sequence.
a cold reset has been performed.
Jan 24, 2014 | HP LaserJet 4730 MFP Printer
Scan streaks with HP LaserJet Pro 200 color MFP M276nw
This may not always be the solution, but in my case it was. If you are getting black streaks on your copies, try this first:
The problem is that that there a small piece of glass that the doc feeder use's to scan the original. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out or other residue, on the glass, just clean with a monitor wipe or take a cloth & wipe, etc...... Good Luck
Online tip from Chris Coughlin, but I changed a few of his words.
Feb 05, 2013 | HP LaserJet Pro 200 color
Hi, I need to reset my Printer using cold reset option. please help.
? Cold Reset
CAUTION All HP Jetdirect settings are also reset. Be sure to print a configuration page
before performing a cold reset. Make a note of the IP address that is listed on the Jetdirect
page. You must restore the IP address after performing a cold reset.
Use this item to unlock menus that have been previously locked and to set all control panel menu
items (including EIO settings) back to the factory defaults. However, using this item does not clear
the values in the SERVICE menu (such as the serial number and page counts).
NOTE Before performing a cold reset, print a menu map and a configuration page.
Use the information on the configuration page to reset any customer-set device configuration values that the cold reset procedure changes.
Apr 14, 2011 | HP LaserJet M5035 MFP Printer
Cold Start
Hi patricia_kin:
Hope this helps.
Cold reset
A cold reset unlocks menus that have been previously locked and resets all control-panel menu
NOTE Before performing a cold reset, print a menu map and a configuration page. See
Information pages. Use the information on these pages to reset customer-specific settings.
configuration page. You will need to restore the IP address after performing a cold reset. See
Configuring and verifying an IP address.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Jul 22, 2009 | HP LaserJet 4345mfp Printer
HP LaserJet Pro 200 color MFP M276nw MFC / All-In-One Color Wireless Logo
311 people viewed this question
Seeker5211
Seeker5211
