Question about Compaq Presario CQ56-115DX Laptop
Diagram replacement screen doesn't light up.. what do I do?
  • Compaq Master
  • 2,072 Answers
The screen probably wasn't bad. It's most likely the inverter board. This is what powers the back light allowing you to see the screen.
Posted on Jul 10, 2013
Diagrams ignition systems
Hi Anonymous, for a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
May 18, 2013 | Harley Davidson FLSTC - FLSTCI Heritage...
Front turn signal works but the running light doesn't
Hi Anonymous, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below: Harley Davidson Wiring Diagrams and Schematics
Sep 03, 2012 | 2010 Harley Davidson FLHX Street Glide
Screen doesn't light up
the batteries are probably not strong enough so buy stronger batteries and if that doesnt work buy a leapster adapter to plug in so that i runs on electricity
Aug 13, 2012 | LeapFrog Leapster 2 Learning System
Machine will not spin
see this causes:
It doesn't pump or spin
frozen pulley pump, or broken belt replace+lid swtich defective
It pumps, but doesn't spin
lid switch defective,motor coupler defective,+belt broke, clutch worn, +drive motor defective, +transmission is not shifting properly+basket drive worn replace. see the diagram
It spins only with the lid closed
safety reasin the spin working with the lid closed
see the diagram .God bless you
Jun 19, 2012 | Fisher and Paykel Washing Machines
Isuzu bighorn wiring diagram
Fixya doesn't have any wiring diagrams. Sorry
Jun 06, 2012 | 1993 Isuzu Trooper
Hello, I have a 85' buick regal and I'm having
This is a tough one with out being able to see the wiring. i will enclose a wiring diagram for the complete lighting system.
You will need to locate the correct wirng and make sure its going to the correct light. Most times a bad ground wire will make the light do funny things like your car is doing. With the diagram i enclose locate the ground wire to the rear lights and make sure ground is good, even if you must cut old ground out and run a new ground to a good metal ground.
Mar 18, 2012 | 1985 Buick Regal
Where are the fuses located on a 1994 Honda Civic? My brake lights won't turn off.
I don't have a fuse diagram, but you may want to try pulling the connector off the stoplight switch above the brake pedal. If that doesn't turn the lights off, your relay is shorted and must be replaced. If the lights go out, check the switch to see if the button is springing out or just replace it. Cost is $20 or less at autozone.
Oct 06, 2011 | 1994 Honda Civic
Hi, I have a problem with a 1999 Dodge Ram 1500 series 5.2 Liter. It will crank over but won't start every once in a while it will start and run for about 20 seconds, then it dies and won't start...
check all your vacuum lines. if there is a vacuum leak, the truck will crank, but not start. if you need a vacuum diagram, go to www.autozone.com create a profile it's free, add vehicle. put in the info of your dodge ram. then from the main screen, where it says select a category, select vehicle repair guide. on the next screen select emission controls. on the next screen where it says select a chapter, select vacuum diagrams. as you scroll down just click on the diagram for your engine. hope it helps. good luck.
Sep 03, 2011 | 1999 Dodge Ram
Dome light quit working on 97 explorer. Fuse? - no diagram to check
Skins, I am sending you a schematic for the dome light.. Check fuse #27 in the Instrument fuse panel. It should be a 10 amp fuse. It on another drawing than this one.. Best of Luck!!
Aug 28, 2011 | Ford Explorer Cars & Trucks
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Jun 21, 2011 | Dryers
Compaq Presario CQ56-115DX Laptop Logo
21 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
