Question about Samsung Cell Phones
Refresh code screen not coming
  • 3 Answers
Phon lock password
Posted on Jul 09, 2013
My optiplex 320 is making two high pitched beeps on starting boot, also im not getting anything on the monitor
James,
It sounds like the refresh rate is set to high. Since you do not mention what OS is installed I have listed information on how to change in Windows,XP.
Start the computer and press the F8 key. Choose Safe Mode. Once the system gets into Windows follow the steps below and then restart the computer. If this does not resolve your issue email me at my email address below and include your OS information.
How to Change the Screen Refresh Rate of Your Monitor
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Or your system is giving off a beep code in which case the beeps come in a 3 beep sequence. Below is the beep codes and what each represents.Beep Codes
Troubleshooting steps and more information about the OptiPlex 320 beep codes Beep Codes Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3-1 through 2-4-4 DIMMs not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller Test failure 3-3-1 NVRAM power loss 3-3-2 NVRAM configuration 3-3-4 Video Memory Test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No time tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math coprocessor test failure 4-4-4 Cache test failure
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Sep 18, 2013 | Dell Computers & Internet
Laptop screen keeps flickering
Changing the refresh rate might help.
Right click on the screen. In the box that comes up select Graphic Properties. In the window that comes up click information. Box that comes up select monitor tab. Will have a list of display sizes and refresh rates that are supported by your monitor. Once you have that information you can make changes.
FYI: Acer says max resolution 1920 X 1080 with 75 HZ refresh rate.
Also if you have a tube light or speaker system close to the monitor then try moving it further away.
Apr 30, 2012 | Acer Computers & Internet
How to troubleshoot flickering, jittering, shaking, or wave-like images on a LCD monitor. 1) Connect the display to the computer. 2) Turn on the computer.
Any monitor has something called a screen refresh rate. If you are replacing your old monitor with a newer one, there is sth called a screen refresh rate that you need to configure. Older monitors (size also matter) have a lower screen refresh rate than the newer ones. If that happens to be your case, find the refresh rate of your new LCD on its manual and adjust it like this.
  1. Right click on an icon free area on your desktop.
  2. Click Properties
  3. On the Property dialog click on the Settings Tab
  4. At the bottom of the form click on Advanced
  5. On the coming property dialog click on the monitors tab
  6. Under Monitor Settings you will find the screen refresh rate combo box, here select the rate that suits you screen and click apply.
  7. confirm your actions in the confirmation window.
Note: Be sure to select a screen refresh rate that matches your screen. If you select a rate bigger than the LCD's capacity you will end up with a black screen on your monitor and won't be able to see the desktop unless you boot in safe mode.
Nov 25, 2009 | Sony VAIO VGN-CS220J/W Notebook
On Farmville,when I harvest or plow,A popup comes on and says I am not in sync with the page.Thwn it says code g3 or g4 I refresh and all the crops grow up again. This has been happening all day.
It happens sometimes. try try to refresh it and it should fix the problem. i faced the similar problem i refreshed the page and it started to work. Press F5 key on the keybaord to refresh the page. or else just log out and log back in again. i tried it and it works. ;)
Sep 21, 2009 | FixYa Computers & Internet
Refresh code for nokia 6300
sir there is no refresh code for nokia there is hard reseting which refresh your phone it works fast hard reseting code *#7780#
Sep 09, 2009 | Nokia Cell Phones
I plug in my mp3 player into my computer, computer is on open everything like i use to have it when it did charge but now the screen comes on and sits, then i take it off and i cant turn it on for more...
When the mp3 player is plugged in to the computer, it won't respond to anything except the computer- the screen will just sit there and say it's connected. After you unplug it, it probably doesn't respond for 3 seceonds because it's refreshing its media. It might tell you it's refreshing or just refresh without saying anything.
Aug 10, 2009 | Mach Speed TRIO Onyx MP3 Player
SET MY REFRESH RATE TO TOO HIGH...AND NOW ALL I GET IS A BLACK SCREEN WITH A LOGO SAYING THAT THE MONITOR DOES NOT SUPPORT THE SETTINGS...CANT GET TO THE SETTINGS TO CHANGE REFRESH RATED BACK TO...
try booting in safemode .. to do that.. reboot computer, as soon as it starts coming up, hit f8, then with the menu that comes up hit, start in safe mode, when windows starts up, just change refresh rate back, and then reboot normal...
Jun 21, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Unlocking my KE 970
type 2945#*# and a engineering menu will appear then select factory reset,the phone after resetting,restarts automatically and put your unlock code to the default one(0000)
Jun 03, 2009 | LG Shine KE970 Cellular Phone
Refresh database on screen
how do you put on recovery mode?
Dec 01, 2007 | SanDisk Sansa e260 MP3 Player
Cell Phones Logo
15 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
