Arthur martin washing machine LF0844
How to set spin cycle
  • 67 Answers
SOURCE: duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Posted on Mar 20, 2007
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
Hello The washing machine is not going through
The lid switch has failed. It will not spin because it is a safety device.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 22422 Top Load Washer
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not spin out - agitates ok but not spinning -
My HLP21R can not spin the clothing after the Rinse mode. What kind of part do I need to fix it myself.
Arthur Yu
Jul 27, 2009 | Haier HLP21E Top Load Washer
Hotpoint WF320 wont spin or empty
sounds like something is jamming the pump, strip pump down and clean
May 26, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Dishwasher drains continuously
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Mar 27, 2008 | Dishwashers
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
