Question about Refrigerators
Liebherr kdes 3142 - Freezer won't freeze
Hello I've got a fault with my refrigerator. The freezer compartment will not freeze at all. Any suggestion what to check before buying new unit?
fridgetech
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
allbrands
  • 600 Answers
SOURCE: freezer not freezing but cools
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
Posted on Jun 06, 2011
  • 842 Answers
SOURCE: Hello. I have this fridge-freezer,
By your description you may have a compressor problem. The noise is makes if a buzzing noise when it struggle to start (locked up). The clicking noise would be the relay clicking out on overload to the compressor.
If your correct on the date, you will be better off replacing the unit then looking into the repair, a normal compressor change out can run over 500.00. Your best bet is to cut your losses and replace the unit before spending any more money on it.
Good Luck
Posted on Aug 28, 2011
Testimonial: "Thanks for your advice. I suspected that was the case. Good to hear it from an expert (although it's going to be an expensive outlay).Much appreciated"
How to adjust the thermostat
Hello Keith Wertheim,
Your freezer MAY-BE SET to COOL or your food might be blocking proper AIR-FLOW... CHECK these FIRST before
SETTING ANY CONTROLS...
Set freezing level first... (close below freezing)
THEN set refrigerator levels last...
(very close ABOVE freezing)
- Before setting ANY MILK, MEAT and/or VEGETABLE
CONTROLS are set to MIDRANGE...
The ENTIRE APPLIANCE should be ALLOWED TO
STABILIZE (run un-molested) for 24 - 72 hours BETWEEN ADJUSTMENTS.
PATIENCE works the best/fastest...
My apologies just because this has become a GLOBAL site... I'm TYPICALLY an unapologetic Fahrenheit (°F) kind of guy. Since this is actually a GLOBAL site
32 DEGREES is freezing point in Fahrenheit (°F)...
((WIKI conversion discussion at VERY BOTTOM)).
>> Depending one what refrigerator you HAVE...
And... your personal preferences...
Your refrigerator is set very CRITICALLY ABOVE
32 Degrees Fahrenheit (°F) = FREEZING...
but below 40 degrees
(for safely/longevity)
((Don't care about Celsius/Centigrade or Kelvin)).
Your owners manual directs you though SET-UP.
(all that is available on-line as well by searching your model+owners+manual).
Once you are SET-UP (level, square) ...
TEMPERATURE "SETTING" it is a bit of a balancing act
(I recommend you buy 2 ( refrigerator + freezer ))... between the freezer hardness (LARGE range of operation) and the REFRIGERATOR (very SMALL range of operation)
FREEZER working range -20 degrees up to FREEZING.
If it is "A Thermostat" one compartment will necessarily have to follow the OTHER... In MOST cases you simple DETERMINE
WHAT LEVEL OF HARD-NESS you FIRST WANT in your
ICE CREAM... (freezer adjustment first).
INTERESTING...
I have JUST DISCOVERED... a new TWO EVAPORATOR
design ... More fun.
Kelvin Wikipedia the free encyclopedia
Jun 12, 2016 | Refrigerators
What could the problem be; my refrigerator not cold but the freezer is freezing?
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail with illustrations how to dx and fix: Refrigerator Defrost Parts
Jul 31, 2014 | Emerson Cr500 Refrigerators & Freezers
Refrigerator-freezer won't freeze
I think the fridge is low on gas, or the defroster is on all the time
Mar 24, 2013 | Whirlpool Refrigerators
Freezer does not freeze anymore
the freezer usually has the condensor coil sandwiched ilong the outer cabnet and in the back the lines come out in to the compressor compartment as a tech i have found the steel line rusts where the epoxy coating is no longer in tact so i would say you most likely have leaked out the refrigerant
Feb 10, 2013 | Freezers
The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
Oct 18, 2012 | Liebherr Refrigerators
T36it71nnp freezer shuts down
Compressor sounds at fault, rather than pcb.Replacement required?
May 10, 2012 | Thermador T36IT71NNP (196 cu ft) Bottom...
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Hi, I've got a Hotpoint RLS175 fridge which doesn't cool. At first there was a buildup of ice on the rear of the fridge compartment but now it doesn't cool at all. At first I thought it was a...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 20, 2011 | Hotpoint RLA50 Refrigerator
Hi,i have a liebherr fridge freezer and the fridge compartment is freezing every thing even with the dial turned down.any idea what might be causing this?
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
Leo Ponder
imufo2
Sep 17, 2011 | Liebherr Refrigerators
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
