Question about Samsung Televison & Video
Colour tv circuit diagram cs568bs
Ihave ctv samsung CS568BS PROBLM IS NO PICTURE NO SOUND RASTER WITH RETRACE LINES PRESENT TDA8842 RGB OUTPUTS ZERO BUT OSD IS PRESENT I CHNGD 8842 IC NO IMPROOVEMNT KINDLY GIVE ADVISE OR ITS CKT DIAGRAM PLEASE.
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Blue Saturation with retrace lines visable
could be but there are a few checks that need to be donr first.. Try to turn down the g2 control just a bit on the flyback transformer. If no effect unsoder the blure drive transistor on the crt board If the blue is still there that means the crt is shorted and you could try to clean the elements with a crt rejuvenator and see if that helps. If the screen goes to red and green after you disconnect the blue drive transistor then you need to check the osd drivers as well as the rgb output drive from the video IC. If the blue gun in the tube shorted or leaky I have in the past and it really works a isolation transformer that plugs in to the crt socket and the other end plugs into the crt. What this does is isolate the the gun of the crt from the filiments and thats where they get shorted or leaky but for how long it will last who knows.
Posted on Mar 26, 2006
techman
  • 3130 Answers
SOURCE: Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Posted on Dec 27, 2006
SOURCE: TELEVISION CHASIS HAVING TDA 9370 SINGLE IC
Try zener from abl.
Posted on Sep 13, 2010
Tip
White Raster with thin lines; Sound Ok.
White raster with retrace lines: No picture, Sound OK
(picture tube based telivisions.)
It is a common fault to occur in most of the CRT based telvisions, regardless of which brand it is. There will be sound OK, and a bright screen with thin white horizontal lines across; at about an inch space, all over the screen area. This fault may occur along with colur shades also, like blue screen with white retrace line, red screen with white retrace lines, green screen with white retrace lines. Let us take the first case. A white raster with white thin retrace line acorss the screen. These are call vertcial retrace lines technically. To make it mor understand, we have to go to some picture tube electrode details. There are three colour cathodes for a colour picture tube, Red, Blue and Green. Two girds are there called Focus and Screen. Focus grid is supplied with focus voltage which in turn determine the cocus of picture, and screen grid is supplied with screen volrage which determine the emission of the picture tube; in short. There is a final anode to all the picture tubes, which supplied with Extra High Tension voltage, can be located at the top side of the picture tube, to which the EHT voltage from LOT is connected with the help of rubber ****** and clip. Without these three voltages, EHT, Screen and Fcous, no raster will be produced. Therefore in our case, there is a raster, so, horizontal output section including Line Output Transformer [LOT] is functioning well, and as far as sound is there, tuner and video IF section are working well. In fact, all other section except, video output section is working properly.
There are three cathode points on the base card, marked as Bk, Rk and Gk. Check the voltages of these three cathodes. In our case, it will be very low or approximately equal to zero. When cathode voltages goes low, emission of the CRT increases, is the reason. There must be a voltage between 120 and 135VDC at these points. Find out the reason for this voltage drop is the next step. The video drive voltages in most TVs comes from LOT windings, after rectification and filtering. There will be one reisitor of low value, say one Ohms or so, will be connected series with this winding, in between diode and winding. Check the voltage at the cathode of this rectifier diode first. If found low replace the diode and the smoothin capcitor. The smoothing capacitor will be between 33 and 47MFD 250VDC rating. Replace both of them. If there is volatge, say 200VDC or so, check whether this voltage comes to the CRT base board or not, If not, check the conducting wire, serial resistors; if used for open. There is no chance of transistor shortage at this time as the raster we see is white. If raser we see have a specific colour predominent, that is green, blue or red, check the revalent video out transistors and replace it. It is best to replace all the three video output transisors at the same time with same batch and number.
on Apr 18, 2011 | Televison & Video
In LG 21" CTV, there is no raster on screen and sound is normal. When increasing screen of FBT only plain raster with retrace lines are appeared. when measuring voltage at cathode of CRT, picture apears...
Hi
Please try testing each voltage of RGB output in the small pcb attached to the CRT. If one of these voltages is missing (they are tipically almost of the same value), replace its output transistor. If all voltages are present, but very high (above 180V), please check the filter capacitor in the RGB supply voltage line near the flyback transformer (47uF/150/200V) by replacing it. It is cheap.
Please be careful when dealing with high voltage section of a tv set as capacitors may store a letal voltage. So disconnect the set from main and discharge any capacitor before dessoldering it.
If this helps you, I shall be glad.
Sully
Sep 26, 2013 | LG Televison & Video
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Lines at top of screen
I have seen issues with complaints of raster with vertical retrace lines at the top of the picture and capacitor 2494 needs to be removed.
Jul 23, 2008 | Philips 27MT3305 27" TV
To repair a tv set
If it has white out with screen retrace lines it means that the 130-200 volt line is missing from the flyback transformer to the neck crt board. begin by checking if the .68ohm to 1ohm fusible resistor is open circuit.if it is then you either have a defective rgb drive chip, or in most sets a shorted drive transistor. a defective gun in the tube can also take out the fusible but unlikely.
Jul 09, 2008 | Televison & Video
Poor picture
In CRT board isolate RGB input. Check plain retrace lines appears in white colour. Then jungle ic failure. Otherwise problem in crt board. Maybe dry soldered.
Aug 18, 2007 | Sony KV-36FS12 36" TV
Circuit board was damaged in electrical storm. Replaced with new board. Now, screen comes on full raster, but with retrace lines. Picture is very faded and barely visible behind lines. Sound is OK and...
I am unable to find in your statement about which brand or type of motherboard is used. One thing i come to know your using service mode kit. knowing in your statement your are a technical person. My simple idea is first you set the TV in standby mode using remote. Then in FBT reduce the screen control minimum position, the release standby. Now the tv is oscillated, now slightly increase screen control till get maximum video and zero retrace line set in position. Even no improvement give me clear picture of brand and microprocessor ic etc. there is a chances to solve by having the above details.
Aug 27, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
