Question about Kyocera Mita Office Equipment & Supplies
Km2050 c0210
Problem c0210
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
Main board and engine board not communicating.Try switching off at the wall for 30 minutes.
Posted on Oct 24, 2013
Sir I have Minolta buz 210 error code
Code: C0210
  • Description: Abnormal image transfer voltage
    - The image transfer voltage remains more than 100 V continuously for a given period of time while the PC Drum remains stationary.
  • https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20210
    Jun 29, 2017 | Minolta Office Equipment & Supplies
    C220 error code& solution
    C0210
    Mar 01, 2014 | Minolta bizhub 180 Black and White Copier
    Hw do i fix error code c0210 on my minolta dialta di 552
    Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is two fold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire mite be broke, has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. if it comes back have qualified tech look at it.
    Mar 09, 2013 | Minolta Office Equipment & Supplies
    How to fix the C0210 Error on minolta dialta di1610?
    The C0210 error code deals with the Primary charge unit... It is part of the drum unit. It may not be installed correctly or it is not in all the way..... Good Luck
    Jun 06, 2012 | Office Equipment & Supplies
    Error code c0210 on minolta 6001
    The Transfer separation assy. Located below the drum has two fine wires in side of it that apply several thousand volts to the paper as it goes above the wires and below the drum to transfer image on to paper the second wire prevents the paper from sticking to the drum. Remove assy. see if they are broken or then the end blocks (white) need to be replaced because after a while the plastic breaks down an the High Voltage go thru the plastic to ground. Clean the wire very, very carefully with pencil earser if never been replace go to the web site below for corona wires don't lose those small springs at one end.
    Precision Roller Printer Toner Cartridges Parts and Supplies Office...
    Apr 11, 2012 | Minolta Office Equipment & Supplies
    I have fault code C0210, what does it mean and how do i access service mode on copier docujet 3016F
    maybe there is a leak on charging assembly or in the transfer assembly check those two partscheck the corona wire maybe its broken or dirty try to clean it
    Dec 17, 2010 | Office Equipment & Supplies
    My Panasonic FP-7160copier is showing code: c0210. What does it mean?
    C0210 indicates a problem with the Transfer/paper separator corona unit.( the one below the drum)..it is either dirty, not installed properly or may need replacement.
    Nov 05, 2010 | Panasonic FP-7735 Black and White Copier
    We have an error - C0210
    k Normal 0 false false false MicrosoftInternetExplorer4 Transfer roller voltage problem
    Jun 08, 2010 | Konica Minolta Di1610 Copier
    En Mi fotocopiadora aparece El error c0210
    Change the transfer/separator corona unit,or clean the corona holder parts.
    May 13, 2010 | Minolta DI-2010F Copier
    115 people viewed this question
    Top Kyocera Mita Office Equipment & Supplies Experts
    Kyocera HP Expert
    Adorjani Laszlo
    AAAA262430
    Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
