Question about Canon iR 5075 AllInOne Printer
Error finisher e540-8002 - Canon iR 5075 AllInOne Printer
What is the sp mode richo aficeowhat is the sp mode richo aficeo
he following error messages will appear on Gestetner, Lanier, Ricoh and Savin products control panel. There are no codes listed in service for operator/user problems. SC-101 Exposure lamp, lamp stabilizer board, dirty white plate, dirty optics, SBU board, CCD SC-103 Power problem SC-104 Exposure lamp problem, main relay optics board, electrical noises or communication error SC-105 Zero cross, main relay, optics board, FUSE 804 on DCPS or AC drive board on FT series SC-120-123 Scan home problem, sensor, scan motor, (EX-IPU board or fuse FU103 Aficio 400, 401, 500) SC-121 Scan home or fuse FU4 Scan home or fuse FU106 Aficio 550/650 SC-124 Scan motor encoder or scan motor SC-125 Scanning to slow speed SC-126 Scanning too fast speed SC-127 Scan motor or optics board SC-128 Scan start speed wrong; motor, board, drive section SC-129 Scan speed problem; motor or PSU SC-130 SBU error SC-140 / 141 Lens vertical home sensor SC-142 / 143 Lens horizontal home sensor SC-144 /145 3rd scan home sensor problem SC-190 EX-IPU board Aficio 400, 401, 500 Optics thermistor FT 7950, 7960, 7970 series SC-192 Automatic SBU adjust error, SBU, BICU, exposure lamp regulator, exposure lamp, dirty white plate SC-193 APS sensor FT 7950, 7960, 7970 series SC-194 IPU white level detect (too low) same as 192 SC-300-303 Charge corona SC-302 Laser (polygon) motor problem SC-302 Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650 SC-303 Charge corona wire cleaner, disconnected or time out for printer SC-304 Charge roller problem, ID sensor problem SC-305 Time out error for memory or EX-IPU board or fuse FU103 on Aficio 400, 401, 500 SC-310-314 Potential sensor SC-320 Laser motor problem SC-321 Laser write problem, BCU board, EX-IPU board SC-322 Laser 1 synch. Problem SC-323 Laser drive problem SC-324 Laser drive excess current draw problem SC-326 Laser 2 synchronization error SC-327 Laser 1 home position error SC-328 Laser 2 home position error SC-329 Laser beam pitch error SC-330 Laser diode no initial setting SC-331 Laser diode home error SC-332 Laser diode present position error SC-335-338 Laser motor polygon problem SC-340 TD sensor output error SC-341 Developer motor lockup TD sensor adjust error Aficio 551, 551P, 700, 700P SC-342 TD sensor adjust error SC-345 Toner collect motor lockup Developer bias loss Aficio 551, 551P, 700, 700P SC-346 Toner recycle motor disconnected SC-350-1: thru 5 ID sensor error SC-351 Vsg problem, bad drum, ID sensor SC-352 TD (toner density) sensor problem or bad toner mix SC-353 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-354 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-355 Toner density sensor or under toned SC-356 Toner density sensor or over toned SC-358 Image density sensor, drum, toner spray SC-360 Hard disk drive error 1 SC-361 Hard disk drive error 2 Incomplete drum potential calibration, check imaging formation assembly FT 7950, 7960, 7970 SC-362 Image compression error Hard disk drive error Aficio 551, 551P, 700, 700P SC-363 Data transmission error SC-364 Data transmission time out error Vd out of specs, drum, drum potential sensor, charge corona FT 7950, 7960, 7970 Hard disk drive error Aficio 551, 551P, 700, 700P SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970 SC-366 CRC error Aficio 550/650Vr out of specs, drum, drum ground FT 7950, 7960, 7970 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-367 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-370-01 thru 07 Drum potential sensor error Aficio 550/650 SC-370-374 IMAC error Aficio 551, 551P, 700, 700P SC-376, 380, 382, 384, 386, 388 Data transmission problem Aficio 551, 551P, 700, 700P SC-390 CRC error Aficio 551, 551P, 700, 700P SC-390-1 Toner density sensor error SC-390-2 Toner density sensor error SC-391 Developer bias problem or FU103 on Aficio 550/650 Image storage address error Aficio 551, 551P, 700, 700P SC-392 Toner density sensor SC-395 Developer bias problem SC-400, 401 Transfer roller error Aficio 551, 551P, 700, 700P SC-401 Transfer roller positive error problem SC-401-1 Transfer roller/belt short SC-401-2 Transfer roller/belt open or fuses FU104, FU115, FU116 Aficio 550/650 SC-402 Transfer roller negative error problem or open SC-403 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Scanner problem; BCU, EX-IPU board or SCU on Aficio 400, 401, 500 SC-411 Separator bias SC-430 Quenching lamp error SC-440 Main motor locked or drum motor locked SC-441 Developer motor locked SC-490 Exhaust fan problem or ozone fan problem SC-491 Laser cooling fan locked SC-492 Cooling fan problem SC-493 Bridge fan problem Exhaust fan locked Aficio 551, 551P, 700, 700P SC-494 Fuser fan locked SC-495 Toner recycling unit problem SC-496 Toner collector bottle problem SC-497 Toner recycling motor problem SC-500 Main motor locked Bypass motor locked FT 7950, 7960, 7970 SC-501-1 & 2 1st Tray lift problem SC-502-1 & 2 2nd tray lift motor problem SC-503-1 & 2 3rd tray lift motor problem SC-504-1 & 2 4th tray lift problem SC-505 LCT tray SC-506 Optional tray motor locked SC-507 LCT motor locked SC-508 Tandem rear fence motor SC-509 Tandem side fence motor SC-510-1 & 2 LCT lift problem Paper feed motor problem Aficio 551, 551P, 700, 700P SC-511 Tandem side fence motor error LCT motor error Aficio 551, 551P, 700, 700P SC-515 Tandem rear fence motor Aficio 551, 551P, 700, 700P SC-516 Tandem side fence motor Aficio 551, 551P, 700, 700P SC-520 Duplex or fuser drive problem FT 7950, 7960, 7970 SC-521 Duplex side fence drive problem SC-522 & 523 Duplex jogger home position FT 7950, 7960, 7970 SC-524 Duplex end fence drive problem SC-530 Bypass motor locked or fuse FU106 on Aficio 551, 551P, 700, 700P SC-531 Fusing duplex motor locked SC-541 Fuser thermistor open SC-542 Fuser temperature too low or fuse FU107 on Aficio 551, 551P, 700, 700P SC-543 Fuser temperature to high SC-544 Fuser temperature too low SC-545 Fuser temperature to high SC-546 Fuser ready temperature unstable SC-547 Zero cross problem Fuser lamp stays on, AC drive board, optics board FT 7950, 7960, 7970 SC-548 Fuser unit not installed SC-590 Toner collector motor problem Cooling fan Aficio 220/270 series SC-591 1 bin tray motor SC-600 Communication problem between SCU and operation SC-601 Communication problem between BICU and scanner Communication problem between BCU and EX-IPU board Aficio 400, 401, 500 Communication problem between SBU and SBICU Aficio 550/650 Communication problem between MCU and BICU Aficio 551, 551P, 700, 700P SC-602 Communication problem between BICU hard disk drive board Communication problem between BCU and fuser control unit on Aficio 400, 401, 500 Communication problem between Hard disk drive board and SBICU Aficio 550/650 Communication problem between BICU and hard disk drive board Aficio 551, 551P, 700, 700P SC-602-2, 2, -3 Communication problem between BICU and ADF SC-604 Communication problem between BCU and high voltage board SC-605 Communication problem between SCU and BCU SC-610 Communication problem between IOB and duplex unit SC-610, 611, 612 Communication problem between BICU and ADF SC-620 Communication problem between BICU and ADF SC-621 Communication problem between BICU and finisher SC-623 Communication problem between BICU and paper tray unit SC-624 Communication problem between BICU and LCT SC-625/626 GA5 data transfer error; EX-IPU or software Communication problem between BICU and finisher Aficio 551, 551P, 700, 700P Communication problem between BICU and LCT Aficio 1035, 1045 SC-627 Communication problem between BICU and LCT Aficio 1035, 1045 SC-630 Communication problem between line adapter and CSS center (Japan) SC-635-636 Communication problem between BICU and paper feed board Aficio 551, 551P, 700, 700P SC-640 BICU data transfer sum check error SC-641 BICU control data transfer problem SC-650, 653 Key card (Japan) SC-670Engine or BICU error SC-672 Op panel to controller problem SC-690 BICU problem (12C) SC-691 Communication problem between BICU and fax controller BICU problem (12C) Aficio 1035, 1045 SC-692 Communication problem between BICU and print controller board BICU problem (12C) Aficio 1035, 1045 SC-694 Communication problem between BICU and scanner board SC-696 Communication problem between IOB and finisher SC-700 ADF P/U problem SC-701 ADF P/U problem SC-702 ADF feed in motor SC-703 ADF transfer motor SC-704 ADF feed out motor SC-705 ADF bottom plate motor SC-720 Finisher transport drive motor problem SC-721 Finisher tray shift or shift motor problem SC-722 Finisher jogger motor SC-723 Finisher stack feed motor problem SC-724 Finisher stapler hammer motor SC-725 Finisher stack feed out motor SC-726 Finisher shift/lift motor SC-727 Finisher stapler rotation motor SC-729 Finisher punch motor SC-730 Finisher stapler position motor SC-731 Finisher exit guide motor Finisher exit open/close motor problem Aficio 1035, 1045 SC-732 Finisher up tray shift motor problem SC-733 Finisher stack feed out motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-734 Finisher lift motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-735 Finisher exit guide motor Finisher pre-stack motor Aficio 551, 551P, 700, 700P SC-736 Finisher exit guide plate motor SC-737 Finisher waste stapler full SC-738 Finisher shift tray lift motor SC-740 1000 sheet finisher error 01: Shutter error 02: Exit error 03: Upper exit plate error 04: Jogger motor 05: Stapler motor 06: Stapler hammer motor 07: Tray lift motor 08: Shift tray height sensor 09: Back up RAM 0A: Communication error SC-741 1000 sheet finisher error in saddle stitch area o 01: Position plate motor o 02: Folder roller motor o 03: Shutter guide motor o 04: Booklet jogger motor o 05: Stapler motor o 06: Folder plate motor o 07: Connector o 08: Switch SC-750 Interchange connection problem SC-751 Bridge connection SC-752 Finisher connection SC-760 ADF gate problem SC-770 Shift tray motor SC-800 Control board bad SC-804 Control board bad SC-819 Software application error SC-820 Control board or software SC-821 Control board SC-822 Bad HD SC-823 Bad control board or NIC SC-824 NVRAM or battery bad SC-826 NVRAM bad SC-827 Memory problem SC-828 Bad control board or firmware SC-829 RAM DIMM or control board bad SC-835 Control board or connector SC-836, 837 Font ROM bad SC-838 Clock generator problem SC-850 NIB or control board bad SC-851 IEEE 1384 interface board or control board bad SC-860, 861 Hard drive problem, connection or cable SC-862, 863 Returned, Bad sector in hard drive SC-864 Abnormal HD data transfer SC-865 Hard drive error SC-900 Electrical copy counter problem reached 10 million or NVRAM problem SC-900-01 Mechanical counter SC-901 Mechanical counter or fuse FU4 SC-921 MSU hardware error Copier feature expander hardware error Aficio 220/270 SC-940 Main switch problem or main board SC-951 Gate signal error SC-953 Scanner image setting error (Software) SC-954 Printer image setting error SC-955 Memory setting error SC-956 Scanner parameter error SC-957, 958 Scan error SC-959 Printer setting ID error SC-960 Printer return ID error SC-961 Printer ready ID error SC-962 Memory setting ID error SC-963 Memory finishing error SC-964 Printer ready error SC-970 Scan error SC-980 Program loading error or hard drive access error SC-981 Hard drive response error SC-982 Hard drive construction error SC-984 Hard drive response error Control board, BICU or connection bad Aficio 1035, 1045 SC-985 Control board, BICU or connection bad Aficio 1035, 1045 SC-986 Software problem SC-990 Communication problem between BICU and input output board or software performance error SC-991 Software problem SC-996 FCU board or firmware problem SC-997, 998 Software or missing RAM or missing DIMM SC-999 Program version error or fuser FU6 Program download problem, BICU, IC, NVRAM bad, power loss, board installed wrong Aficio 1035, 1045 Printer Controller Error Codes 2001 Power on error 2002 FGATE error 0201 On board SDRAM error 0301 SDRAM error 0Fxx Controller -BICU error 1101 Data transmission error 1102 Data loop back 11xx Centronics cable error 1401 Controller NVRAM error 1402 NVRAM check sum error 1403 NVRAM white error 1404 NVRAM read error 1501 RTC error 1601 Font ROM error 1602 Data in font ROM is damage 1Bxx Options bus A error RICOH 3813 Copier U1 Right side open U2 No key counter U4 Sorter not latched or closed U6 Developer unit not in place E11 Exposure lamp problem E12 Exposure lamp problem E13 Zero cross, main board or power supply E-14 Zero cross, main board or power supply E-21 Scan home problem E-22 Scan home problem E-28
May 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
How to fix the error code for Ricoh 1232c sc517 and how to clear it
there's no error code like that
http://www.unitedtechsonline.citymax.com/page/page/4653767.htm
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER)
384-385:IMAGE DATA TRANSFER PROBLEM WHEN TANDEM IS USED(SBU,INTERFACE
BOARD,SICU,PRINT CONTROLLER)
390:TANDEM IMAGE DATA TRANSFER ERROR(NOISE,SICU,INTERFACE BOARD)
391-392:IMAGE STORAGE ADDRESS ERROR(SICU391-01)
395:CD-R/RW ERROR, INTERFACE BOARD ISSUES
397:CD ACCESS ERROR
398:CD-R/RW DATA ERROR
400:TRANSFER BIAS ROLLER ISSUES
401:TRANSFER ROLLER
430:QUENCHING LAMP ERROR
440:DRUM MOTOR LOCKED
441:DEVELOPER MOTOT LOCKED
491:LASER COOLING FAN LOCKED
495:TONER BOTTLE PROBLEM
496:TONER COLLECTOR BOTTLE PROBLEM
501:LIFT PROBLEMS FOR TRAY 1
502:LIFT PROBLEMS FOR TRAY 2
503:LIFT PROBLEMS FOR TRAY 3
504:LCT 1ST TRAY PICKUP OR LIFT PROBLEM
505:LCT 2ND TRAY PICKUP OR LIFT PROBLEM
506:LCT 3RD TRAY PICKUP OR LIFT PROBLEM
510:PAPER FEED MOTOR PROBLEMS
511:LCT MOTOR PROBLEM
515:TANDEM REAR FENCE MOTOR PROBLEM
520-521:DUPLEX JUGGER MOTOR PROBLEMS
531:FUSING DUPLEX MOTOR LOCKED
532:RELAY MOTOR LOCK
541:OPEN FUSER THERMISTOR
542:LOW FUSER TEMPERATURE
543:HIGH FUSER TEMPERATURE
544:HIGH FUSER TEMPERATURE
545:HIGH FUSER TEMPERATURE
546:LOW FUSER TEMPERATURE
547:ZERO CROSS PROBLEM
550:WEB EXPIRED
591:TONER SUPPLY MOTOR PROBLEMS
592:TONER BANK MOTOR PROBLEMS
601:SBICU TO SBU COMMUNICATION PROBLEMS
602:SBICU TO HARD DISK DRIVE BOARD COMMUNICATION PROBLEMS
620-622:SBICU TO ADF COMMUNICATION PROBLEMS
625-626:BCU TO FINISHER COMMUNICATION PROBLEMS
630:LINE ADOPTER TO CSS CENTER COMMUNICATION PROBLEMS
640-645:BCH TO SICU COMMUNICATION PROBLEMS
646:SICU PROBLEM
650-653:COUNTER ERROR JAPAN
701:ADF P/U ROLLER PROBLEMS
702:ADF FEED MOTOR PROBLEM
703:ADF TRANSPORT BELT MOTOR PROBLEM
704:ADF EXIT MOTOR PROBLEM
705:ADF ORIGINAL TABLE LIFT ISSUES
720:FINISHER LOWER TRANSPORT MOTOR ISSUES
722:FINISHER JOGGER MOTOR ISSUES
724:FINISHER STAPLER HAMMER PROBLEMS
725:FINISHER STACK EXIT MOTOR PROBLEMS
726:FINISHER SHIFT MOTOR PROBLEMS
727:FINISHER STAPLER ROTATION PROBLEMS
729:FINISHER PUNCH MOTOR PROBLEMS
730:FINISHER STAPLER MOTOR PROBLEMS
735:FINISHER PAPER STACK PLATE MOTOR PROBLEMS
736:FINISHER EXIT GUIDE MOTOR PROBLEMS
737:FINISHER FULL STAPLER HOPPER
738:FINISHER SHIFT TRAY LIFT MOTOR PROBLEMS
739:FINISHER FOLDER PLATE MOTOR ERROR
740:FINISHER FRONT SADDLE STITCH STAPLER MOTOR PROBLEMS
741:FINISHER REAR SADDLE STITCH STAPLER MOTOR PROBLEMS
742:FINISHER JOGGER SIDE FENCE MOTOR
750:COVER INTERPOSER BOTTOM PLATE MOTOR PROBLEMS
800:VIDEO OUT TRANSFER,CONTROLLER BOARD
804:VIDEO OUT TRANSFER,CONTROLLER BOARD
818:OPTIONAL BOARD,CONTROLLER BOARD, SYSTEM PROGRAM
819:BAD SOFTWARE
820:CONTROLLER BOARD OR SOFTWARE
821:CONTROLLER BOARD
822:HDD PROBLEM
823:NIB, CONTROLLER BOARD
824:CONTROLLER BOARD, NVRAM
825:NVRAM ERROR
826:NVRAM
827:CONTROLLER BOARD, RAM
828:SOFTWARE,ROM,CONTROLLER
829:RAM, CONTROLLER
835:CONTROLLER,CENTRONIC LOOPBACK CONNECTOR
836-837:FONT DEVICE
838:CONTROLLER BOARD
850:IP ADDRESS,CONTROLLER BOARD,NIB
851:1394 I/F CONNECTIONB,I/F INTERFACE,CONTROLLER BOARD
860-861:HDD
862:HDD BAD SECTORS
863:HDD
864:DATA TRANSFER ISSUES
865:HDD
900:NVRAM PROBLEM.ELECTRICAL COPY COUNTER
901:MECHANICAL COUNTER ISSUES
921:IMB, BICU FAILING
922:IMB, BICU FAILING
924:DRAM,BICU,IMB FAILING
925:BICU, IMB FAILING
926:BICU, IMB FAILING
951:F-GATE SIGNAL ERROR PROBLEMS
953:SCANNER IMAGE SETTING ERROR ISSUES
954:PRINTER IMAGE SETTING ERROR ISSUES
955:MEMORY SETTING ERROR ISSUES
964:PRINTER READY ERROR ISSUES
966:POLYGON MOTOR PROBLEM
970:SCANNER READY ERROR
980:HDD ACCESS ERROR
981:BICU, NVRAM
982:HDD CONSTRUCTION ERROR
984-987:HDD DATA TRANSFER ERROR
990:SOFTWARE PERFORMANCE ERROR
991:REBOOT SOFTWARE ERROR
997-998:DIMM, RAM ERROR
999:PROGRAM DOWNLOAD ERRORS
Oct 29, 2008 | Ricoh Office Equipment & Supplies
I have a ir5070 that is getting a E000584 AND E00014. Trying to find a list of error code descriptions but now luck. Anyone know what they mean or why I am getting these?
the error 14 is fixing unit error a dn 584 is finisher shutter error
first disconnect the finisher and solve the fixing error 14
reset the error
copier>function>clear>err>ok and reboot
once the unit is ready to copy run 10 copies to confirm
then connect the finisher and solve the next error 584
Oct 25, 2013 | Canon Office Equipment & Supplies
Scan error
The error code refers to the hard drive for the finisher. If you want to avoid replacing the hard drive, you can just take the finisher off. The hard drive is used to store print jobs when making sets of copies with the finisher... Good Luck
Jun 06, 2013 | Gestetner Office Equipment & Supplies
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
Malfunction detected C-0096
Code Item
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
Feb 10, 2009 | Kyocera Office Equipment & Supplies
Canon iR 5075 AllInOne Printer Logo
178 people viewed this question
old marine
old marine
