Ibm ps 1
My ibm ps/1 2121 does not turn on, I can hear the fan go once and stops. Nothing shows up on the screen and it won't light up. Is it the monitor, or the computer? The monitor does not light up or does anything, but I can hear it warm up.
  • 2,072 Answers
Most likely it's a power issue.
Posted on Jul 10, 2013
  • 3 Answers
SOURCE: screen wont light up, cannot see the screen.
press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Posted on Feb 06, 2009
fossildude
  • 832 Answers
SOURCE: Compaq NC6400 Turns on but will not display anything on screen.
hi thanks for using fixya!
I recommend that you bring your laptop to a service center to further check the hard ware of your laptop.
Best Regards!
Posted on Apr 12, 2009
  • 10 Answers
SOURCE: Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Posted on Jun 15, 2009
  • 153 Answers
SOURCE: Laptop IBM ThinkPad. Black screen. Short beeps: 1+3+3+1
You can try the following steps:
1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
3. Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
4. Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
6. Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in. (Clean the slots if there are large amounts of dust)
7. Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
9. Disconnect everything and just leave the CPU installed and turn on the laptop.
10. If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
Posted on Jan 27, 2010
SOURCE: My Presario CQ61 won't do anything. No fans.
-Take out the battery,
-Remove main supply,
-Hold power button down for 30 secs,
-Put only power supply in, do not put battery in
-Turn laptop on
-Put the battery in
Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet.
Laptop power not working -::> click HERE
Posted on Apr 19, 2011
Woke up and laptop was still running all lights on but no screen. Won't do anything
There are 2 Explanation
1- your windows is broken and must formet
2- your BIOS is broken
3- your laptop has just taken a kick so some hardware has broken
Dec 13, 2012 | Toshiba Computers & Internet
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
Pc turning off
Be more specific. Turning off when? What happens when you try to turn it on? When you have the power cord plugged in do you see any lights? When you press the power button do you hear the fan running, hear the hard drive running, see anything on the lcd screen, hear the cd drive Click once, see the light on the cd drive drawer turn on for a second or two when it clicks, hear any beeps or blinking lights?
Mar 21, 2012 | IBM Lenovo ThinkPad X40 Notebook
TV HAS RED LIGHT SHOWING WILL NOT SWITCH ON
Hi, The red light shows there is power connected to the set. The fact that it won't power up is due to a problem with the power supply circuit in the set. or a problem with the switch circuit or the mains power transformer. Regards John Ps don't know why they're giving me these questions, I answer questions on auto's
Feb 12, 2012 | Wharfedale Televison & Video
IBM thinkpad turns on but screen stays black!!!!!
i had a t40 with similar issues. something with the video on board chip. can you boot to external monitor?
Jul 10, 2009 | IBM Computers & Internet
Ibm thinkpad a22m turns on, but no screen
diid u change memory or something it means that some hardware is not compatible or broken lik memory mostly it because of that
Feb 13, 2009 | IBM ThinkPad A21m 2628 Notebook
IBM T40 the battery is fully charged but will not power on with the ac
Have you disabled your battery
is your battery showing
check control panel\power options
does your battery show as 100 % charged
then you can also check device manager for battery
Let me know
Jan 29, 2009 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
David Payne
David Payne
