Question about Dryers
Westinghouse dryer ld515
Wall mounting bracket
5 Suggested Answers
SOURCE: I have a wall bracket on the laundry but hjow do I get the dryer on to the bracket
Is the wall dryer bracket, the correct one to fit your hover
Posted on May 28, 2009
SOURCE: Hang Hoover dryer on wall, where to buy brackets?
yes you can. go try any hardwear shop local to you. if you cant find one go to yell.com
Posted on Nov 27, 2009
ginko
  • 19396 Answers
SOURCE: Is it possible to mount the unit upside down on wall brackets.
Hi Don.
All appliances must be installed, used, and also transported and stored with the top side up.
If the dryer is turned upside down the weight of the drum, motor and other parts will not be sustained anymore by the rollers and other structural parts located inside the appliance.
The dryer will start, but it will break down after a short usage.
There are also other safety issues involved.
The dryer cannot be installed upside down.
Regards.
Posted on Feb 26, 2010
SOURCE: hi i have no instructions on how to mount my
ask interiobhasker@gmail.com
Posted on Apr 16, 2010
How do fit a wall bracket on 50 in techwood tv
TECHWOOD 50inches TV Wall Mount Bracket TV BRACKETS TV WALL BRACKETS...
You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
Semper Fi,
Z
Jan 30, 2018 | Televison & Video
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Missing stand
You can get to find alternative mounting by visiting any hardware store. Please find some tips from the link below with which it can be mounted to be fixed on the table or rack.
http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
Dec 10, 2011 | Westinghouse Computers & Internet
How can I put. On my led tv on the wall
You need to purchase a wall bracket for your TV. There are several types on the market. Make sure the mountind holes on the TV line up with the wall bracket mounting holes and it can support the weight of your TV.
Google search for a wall mounting bracket for your model TV.
Nov 21, 2011 | Televison & Video
Can I wall mount my proview tv? do I need to buy a particular mounting bracket?
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
Feb 03, 2011 | Sony SUWL500 Wall Mounting Bracket
What is the weight of model TX-42F430S Television. I am mounting it on the wall. Thank You!
I found 2 different sources online that list the weight as either 61.1 lbs or 68.1 lbs. I think the 61.1 is more accurate for the bare TV without the stand or anything attached. But keep in mind that when mounting a flat panel TV to a wall, you should secure it with hardware rated for much higher weight tolerances. Many mounting brackets for TVs of this size are rated for 150 - 200 lbs, and for good reason. Consider a situation where someone trips and catches his balance on the wall-mounted TV. The TV is already putting 61 lbs of pressure on the bracket, so any force from any other contact is added to that. It doesn't take much to add up to 100 lbs or more. If the mount breaks free from the wall, you'll have damage to the TV, the wall, the mount, and any furniture or flooring beneath the TV, so the best advice is to mount it as if it weighed about 150 lbs. The 7 lbs +/- difference in reported weights won't matter at all.
Jan 25, 2011 | Westinghouse Televison & Video
Dryers Logo
50 people viewed this question
Top Dryers Experts
