Question about Dryers
Fisher paykel parts no power gw621 do I need to get another power board
2 Suggested Answers
  • 3 Answers
SOURCE: parts
You can download parts diagrams and order parts here.
http://fisherpaykelparts.net/
Posted on Feb 03, 2009
Fisher and Paykel washing machine. Model # WA42T26GW1. Have no power at all.Is there a reset on machine???
No. It has a fuse soldered on main board but if no power then usually that means a new board required but also needs everything tested to see if there is a reason board died before installing a new board.
Aug 05, 2017 | Fisher and Paykel Washing Machines
Fisher & paykel washer no power going to it
No reset button. There is a fuse it is soldered on & part of the main control board. They don't blow the fuse for no reason, so you need to be able to test & check everything to find out why the fuse blew (if it has) If you just replace the control board without checking then there is a good chance it may blow the new board as well. There will be no warranty on the board in that case. You really need to call a repair company who will test everything first.
Dec 27, 2015 | Fisher and Paykel Washing Machines
After changing the cold water valve on a GW612 do I need to do a reset
The motor controller board could have a faulty water valve mosfet.
have part replaced by tech or replace motor controller board.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel IWL 16 shuts off during all cycles.
I says power cut restarting in 10 seconds
I'm sorry, it is the board, the switch mode power supply is dying.
Every time it starts to do something it power cuts.
Best to get a new motor controller board,
Quote the 6 digit part number under the bar code to get the right part.
Mar 25, 2013 | Fisher Paykel Eco IWL16
My Fisher & Paykel GWL11 top load wahser will only wash in cold after the first cycle. It
the problem other then the thermosat and solenoid valves is probably the main board. to check you need to replace the board with known good second hand board . buy an old machine for parts
Nov 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
G'day, we've just bought a fisher and paykel wl80
Every one I've worked on a few lately and both of them have had thermistor leaks in to the control board area causing the control board to fail, Sounds like you may have the same problem.. Remove the top control area and check for water. Good luck
May 13, 2011 | Fisher and Paykel Washing Machines
No power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Intuitive eco - no power
Definately need to get a service man out. Sounds like the computer board has failed & the tech will need to check if another part was the cause of the board failure.
Sep 19, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Dryers Logo
11 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
