Question about Medical
Cardiotron vintage ECG/EKG
Looking for info on connecting all the leads, where is the connection for the 5th lead at the pericardium? I cannot find where to connect it on the ecg unit.
5 Suggested Answers
  • 157 Answers
SOURCE: Omron Portable Ecg Ekg accuracy problem
Hello Josh. You will need a EKG simulator. I suggest you contact your local community (junior) college electronics class or a local Bio Medical services in your local hospital. When locating one kindly walk in and ask very nicely with the portable in hand if you my perform a operational test for you on benefit.
Posted on Sep 19, 2008
  • 4 Answers
SOURCE: MALFUNCTIONING LEAD ON ECG MACHINE
U may have problem with thorax electrode.
Posted on Apr 15, 2009
AJIN G
  • 6694 Answers
SOURCE: when we connect leads to patient no thing out in
hi,
check the patient cable. if there is any break ( inside ) in the lead it will this problem can occur. also check is the patient cable properly inserted in the socket or not.
if any lead is broken the ecg will not print, also show interference in the display.
try to change the patient cable.
ok
Posted on Feb 07, 2011
SOURCE: How do I reset the Password for GE Mac 1200 ECG Machine?
The password should be "system." Contact Discount Cardiology for the clips, ekg paper, and whatever other accessories you may need.
Posted on Oct 08, 2012
Do you have a poster for correct lead placement for AT-2 plus ECG? thanks!
hi,
If you need to know how to place the leads then whach the following video. All 12 channel ecg machines have the same lead placement
Jun 23, 2011 | Schiller Welch Allyn Cardiovit At 2...
We use a Welch Allyn ECG machine at our office, and our numerous occassions lately it is saying the the limbs leads are reversed (avR is showing up positive and aVL is showing up negative). How do I fix...
hi,
You have wrongly connected the limb leads. Limb leads are those leads which we connect in the arms and legs.
In your case the leads in the arm have been interchanged. Thats why you get the message and prints inverted avR and avR.
check the leads and properly place it.
ok
Apr 06, 2011 | Welch Allyn Medical
How does ECG machine find that signals are good for printing (in auto mode)? some ECG machines take up to 20 second time for printing start
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
When we connect leads to patient no thing out in ecg paper however before conncting this leads there is noise see in screen
hi,
ok
Jan 18, 2011 | Zoll AED Plus wECG Package Graphical...
What's the difference between a single channel ECG/EKG and a multiple channel?
a single channel records one leads at a time and a three channel records threeat a leads time
Jan 11, 2011 | Schiller Cardiovit At 1 Ecg Machine
Ekg machine states left leg fail, but none of the leads are reading anything. works sometimes, but does this occasionaly. Does anyone else have these complaints?
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Jan 10, 2011 | Life Science Bionet Cardiotouch 3000 12...
EKG Machine
3 lead machines are designed to monitor the cardiac rhythm cycle, in 3 of the 12 primary leads. An attempt to use this limited information as a true diagnostic tool would be incomplete and perhaps misleading.
A full 12-lead machine is diagnostic, and looks at the elecrical information from all sides ("walls", ie anterior, septal, inferior, lateral, posterior) of the heart and gives detailed information regarding ischemia and or infarction of the cardiac muscle, electrical conduction system function, electrical axis, chamber enlargement, drug effects, and more.
Hope this helps.
Apr 23, 2009 | Ge Medical Systems 3 Lead Ekg / Ecg Cable...
Printing 3 leads only not 12
Hello medico001, The info on the Schiller web site states an option of 12 lead for model Cardivot AT. If your unit has this option only the automatic selection will deliver the 12 lead print. For futher info select the web site http://www.schilleramerica.com and click on 'Contact Us'. This should direct you to someone local. Good luck.
Oct 24, 2008 | Schiller Cardiovit At 2 Light Ecg Machine
Medical Logo
54 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Medical Expert? Answer questions, earn points and help others
