Question about Sony Cyber-Shot DSC-T33 Digital Camera
Stilll not working..
When I turn my camera on in pic/video mode it says 'TURN THE PWER OFF AND ON AGAIN' I do... and it just keeps saying it. Any help?? So the solution I was given was to turn the camera off and take the battery out for 30 seconds then do the manual reset.... I tried it ... didn't work... any other Help??
Worked like a charm.  After further investigation, I learned that my wife dipped the camera in cake frosting.
Posted on Oct 28, 2007
Thank you. You just save me $180 dollars. :)
Posted on Oct 20, 2007
Hello! I had the same frustrating problem and was just about to send my camera to Sony for a whopping $180 base repair fee. Anyway this is what worked for me. I think there was something causing the camera lens to stick a bit so I used a flat sharp knife to dislodge it. please DO NOT poke it. Just run the knife blade gently under the rim following the circle. Then turn th camera back on. I hope it works for you!
Posted on Sep 07, 2007
    Problem Solver:
  • 36 Answers
Defective, optical lens assy, most probably the lens cover mechanism, but its integrated in the entire lens assy. When power on, observe the lens cover if will retract or open, if not, then thats it.
Posted on Sep 04, 2007
When turned on just shows black screen. Used to be able to pwer off and back on and would work. Lens issue? Can view pics on memory card just can't take pics anymore.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 14, 2011 | Canon PowerShot S2 IS Digital Camera
DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Jun 04, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Turn camera off and on again -- fried in outlet
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
May 22, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
I tried to film on my camera but it keeps saying card error. now i can not see any of my pics or videos. it wont let me take pics or films either. when i turn on my camera it keeps saying crad error....
Buy a card reader and use it to download to your computer. Then, insert the card back in the camera, go into the menu and scroll to "format"...follow the on-screen instructions.
Nov 17, 2009 | Cameras
Panasonic Lumix camera, DMC FS5
I had same problem. I just got the camera working again. Not sure how it exactly happened but while I had it on and it was zooming in and out, I changed the mode and tried to take a pic. It would ask me to turn off and on again which I would do quickly and change the mode to something else like "portrait" or "landscape", etc. and try to take a pic. After a few times it stopped and focused on something. So not very scientific but doing that must have kicked it in the head or something.
Jun 07, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Camera refuses to switch on
lens mechanism not working properly so only it gives error, so camera says turn the power on. try to tap the lens while power up......
Aug 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Powering off
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
Jun 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Camera Temperature
mine is an everio gz-mg37u and i get that same bulls*** on the screen at every power up. First I tried waiting a while then switching all the switches between camera and video mode, record and watch mode, etc. and one time it worked and the message went away. Haven't been able to do that since.
Now what I do is turn it on, wrap it in a blanket, leave it about 10 minutes, then turn the power off and on again. Works fine for me, and if I turn it off and then turn it back on within a few minutes before it cools down, it works fine. There has to be a messed up sensor in this thing that I can desolder somewhere......
Jun 13, 2008 | JVC Everio GZ-MG130 Camcorder
Need help FAST!! Panasonic NV
remove battery for a while .put it again and try .if not works...remove battery agin then put it again by keeping power switch off. eject and remove cassette .take several eject operations. now try again.
Nov 04, 2007 | Panasonic NV-GS50 Mini DV Digital...
Error message
If this error message appears, turn off the camera and remove the batteries for 30 seconds. Afterwards, reinsert the batteries and turn the camera back on. Perform a manual reset of the camera.
Aug 26, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Open Questions:
Sony Cyber-Shot DSC-T33 Digital Camera Logo
41 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
