Question about Thomson Washing Machines
Thomson Washer Door Lock not working
My front loading washing machine is complaining that the door is not locked, even after I closed the door. The display panel keeps saying Lock the Door.
  • 641 Answers
SOURCE: Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Posted on Sep 08, 2007
SOURCE: Kenmore Elite front loading washing machine
My machine just died. No codes, no nothing. I thought it had blew a fuse. But the outlet is fine. There is no power to the unit. There is a load in the machine and I can't get it out. Help
Posted on Jan 26, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
SOURCE: GE WHDVH626fWW Door Locked, but not
Mine was doing the same thing. Upon closer investigation the drum seal was torn near the door locking mechanism, and when water got on the locking mechanism it shorted it out until it dryed. Then it would work again. You can check this by pulling the seal back on the locking side of the door to see if its torn.
Posted on Aug 04, 2009
  • 4 Answers
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Posted on Aug 19, 2009
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
Front load washer door will not lock
Hello Phyllis Emmett - Do you notice any error codes displayed on the control panel or lights blinking? If so and the panel displays "DR", the door may have a defective door lock switch. However, if panel displays "DDO" either the drawer is not closing, magnet may be missing or have a defective reed switch, which you will need to contact a professional to diagnose the unit.
Sep 24, 2012 | Frigidaire Affinity ATF7000E Front Load...
It keeps dispaling FL in the panel
Hello, the FL displaying on the panel simply means Failed to Lock. Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Solution
Check the wire connections in harness leading from machine control board to door lock mechanism
Check solenoid and door lock enable switch in door lock mechanism.
Replace responsible component..
Thanks
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
May 19, 2010 | Bosch Classixx WFL 2066 Front Load Washer
'Close the Door' on Miele WT 2670
Door lock faulty or wires to lock adrift.
Mar 06, 2010 | Miele WT945 Front Load Washer / Dryer
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
An error signal "DL" - door lock signal keeps coming on
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
May 23, 2009 | LG WM2277H Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
HE3 lock
Have you tried pushing the door lock/unlock button? I think it may be called the "rinse & spin", and under that it says door lock/unlock.
Sep 20, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Thomson Washing Machines Experts
Garth Jackson
highlander28
Level 1 Expert
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
