Question about Radio Communications
Samsung bluetooth model hm1300 manual
Need a manual
Samsung c3050 mobile not connecting to bluetooth handsfree device
There probably is a special procedure for connecting the second device. Consult your user manual for the headset and be sure to follow the steps precisely.
Dec 17, 2011 | Samsung C3050 Cell Phone
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
Samsung bluetooth headset manual AATH200HBE
The AATH200HBE is just a charging cradle.
Do you mean the actual headset that sits in the cradle?
If so, it is probably a WEP200?
The user manual is at http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
Jan 02, 2010 | Samsung Wireless Headset for...
Samsung a177 bluetooth help??????/
I'm sorry buddy because there is no way for your phone to pair up with other BT capable phones because eventhough the phone has bluetooth, it is only capable of pairing up with a bluetooth carkit & bluetooth headset.
The SGH-A177 does not have a File transfer profile (FTP) under the bluetooth profiles that ur phone is supporting.
U need to have another higher model but call Samsung first to inquire if the other Samsung phone you want to buy has a file transfer profile.
check this bluetooth article.
that info is straight from Samsung....
Dec 16, 2009 | Samsung A177 Cell Phone
Need a passkey for samsung omnia
hi, default passkey is 0000. Enter this passkey in the asus notebook when it asks for passkey.
Both the passkey should be same to enable file transfer through bluetooth.
Sep 19, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Lost my user manual. need to know how to turn bluetooth on to my
Last page of this manual for your headset... https://techtrain.samsungwireless.com/tekweb/Misc/Main/Accessories/WEP350_ss.pdf
Mar 23, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Manual for bluetooth headphones FJ-800
www.made-in-china.com here u can see all the feauture
Oct 15, 2008 | Cell Phones
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
