Question about Home
850 sinkmaster garbage disposal jam - Home
3 Suggested Answers
  • 92 Answers
SOURCE: how do i disassemble a sinkmaster 850 disposal
well if it is a typical diposal under the sink up close to strainer there is some type of locking device which either unscrews or needs to be tapped to left to unscrew be careful cause it could end up in your hands real quick you also have to undo electric and connection to trap under sink
Posted on May 11, 2009
  • 122 Answers
SOURCE: The blades on my Sinkmaster 550 garbage disposer
that is a project I wouldn't reccomend. besides the "blades" are not really changable. The blades are a piece of metal cut at an angle and when they spin they grind the food by rubbing against a series of holes in the base.
if the disposal is not grinding the food, then its time to replace the disposal.
Posted on Aug 17, 2010
Titan garbage disposal
Push reset button located bottom of disposal? Use broom stick and rotate stuck cutter disk?
Copy following link to troubleshoot by type of problem:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Titan appears to be repackaged sinkmaster garbage disposal.
There is no service manual or installation manual on brief web search. However link above has manuals sinkmaster and other brands .
Add a comment and say what you discover
Jun 09, 2013 | Garbage Disposals
Sink master 850 disposal parts
Copy following link for disposal parts:
Repair clinic appears to carry the parts ... assuming your sink master is same as sinkmaster
http://www.repairclinic.com/Sinkmaster-Garbage-Disposer-Parts
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#parts
http://waterheatertimer.org/pdf/Sinkmaster-sell-sheet.pdf
There is no clear parts sheet that shows Sinkmaster/GE disposal parts numbers. The product does not have installation manual posted online.
Call Sinkmaster 800-854-3229 to check on parts and ask about 10 year warranty.
May 25, 2013 | Electrical Supplies
The blades on my Sinkmaster 550 garbage disposer needs replacing. How do I take it apart and replace the blades?
Aug 07, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Leaking sinkmaster 850 garbage disposal
I have had these apart. The leak is from a seal around the motor shaft. By the time it is leaking the shaft has pitted to the point a new seal will not repair it. Getting it apart can result in damaged parts as it is sealed together with very tight tolerances and a glue like sealer.
Eric
Jul 02, 2009 | Food Processors
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
