Question about Samsung Computers & Internet
Messed up keyboard
9,O,L, and period is not working
    New Friend:
  • 38 Answers
Hi there ,
have you damaged your keyboard physically ?
dont worry , keyboard problems get resolved very quickly at Laptopsmumbai.com
contact us .
Posted on Jul 09, 2013
My Toshiba satellite L855D loptop not working! the letter, i,o,k,l and number 8, 9 and also the comma (,) and period (.) are not woking !! what should I do!! please help me!!! I can't used my loptop!! for...
The keyboard is dying. It is time to replace your keyboard. eBay.com is a good source; you can buy from USA seller and ship it overnight if necessary. Replacing a keyboard is an easy task; please read your laptop service manual.
Mar 02, 2014 | Toshiba Satellite L855D-S5242 15.6-Inch...
This afternoon my laptop was working fine, then the keyboard started messing up, when I pressed any letter it came up with 4 other letters. Then i pressed '9' once and it continuously typed 9 until I
First thing I would ask is this. Was anything spilled on the key board? I had a situation similar to this and I found that my son spilled a Sprite and wiped it up but didn't tell me about it. One way to check this is to hook an aftermarket keyboard that runs off your USB2 port and see if the keys work correctly that way. If they do, I would suspect that something was spilled into your laptop keyboard.
Feb 06, 2013 | Computers & Internet
My keyboard stopped working after my dad threw a pillow on it absent mindedly, and it messed with my normal keyboard now it just doesn't work at all, its really annoying, i tried new batteries,...
Hi supercrapnst ,
Please follow the below steps..:)
  1. Please make sure that you get your keyboard replaced , in case it's still under warranty , hopefully the supplier would give you a direct replacement.
  2. Check if the keyboard works when connected to your friend's pc , so that you are confirmed that it's not just your pc that is having an issue with the keyboard.
  3. Check if there is any lock key function on the keyboard which locks all the keys together so that you unlock them again with the relevant command , please refer to the manual or the icons on your keyboard , as there are some keyboards which provide this option.
  4. Check the device manger settings, via right clicking on my computer icon --> properties --> hardware --> device manager and see if the keyboard is detected as working properly , if there is an error , you need to reinstall the key board driver and hopefully it will work.
Hope this helps ..:)
May 11, 2011 | Memorex RF 7000 Wireless EZ Touch Keyboard
Compaq presario 700 the keyboard seems all messed up. For example when I press G it types O, when I press S it types a period etc. What would cause this?
Hold the ALT Key and hit the number lock key, It should go back to a normal keyboard.sometimes you need the Fn + NumLk key depends on laptop
Jul 13, 2010 | Compaq Presario 700 470024-192 Notebook
Periodically my enter key stops working and I have to restart to get it working again.
There could be several reasons for this issue.
Reason : 1 Could be a spyware messing up with the keyboard. Use an anti-spyware to detect and cleanup.
Reason : 2 This could also happen due to X-Win 32 7.1 Version.
Upgrade following the below steps.
Upgrade to X-Win32 V8
Modify your keyboard map in X-Win32 7.1 or earlier:
Open X-Config’s Input tab
Click Edit… to edit the keyboard layout
Click on the Enter key (which may be labeled as Ent)
Click in the box labeled Unshifted which should have a value of KP_Enter
Select Keyboard -> Keyboard 8 -> Return from the popup menu
Save the keyboard map and restart X-Win32
Feb 15, 2010 | HP Mini 2140 Notebook
My laptop button 9 O and L not working
Probably a bad keyboard. Most likely the period "." doesn't work either.
Sep 14, 2009 | Toshiba Satellite A135-S2276 Notebook
Keyboard Issues/Errors
I would gather that your keyboard has been changed somehow to another country keyboard. Please check in your control panel, keyboard and see if eng usa is selected.
The other suggestion is pressing and holding fn key, num lock key at the same time. You should see a light going off and on when you do this on your system.
If keyboard selected is english, and num lock is off, I would turn your keyboard upside down and give it a good shake. Sometimes a paperclip, or staple gets underneath the keys.
Jan 22, 2009 | Averatec Computers & Internet
Problem with japanese keyboard
Hello, hope this helps. Special characters in a friend's Thinkpad 2662 were helped by going into regional settings as described below:
http://forums.lenovo.com/lnv/board/message?board.id=Beta_OS&thread.id=369
May 03, 2008 | IBM 02K6212 for ThinkPad R31 Series...
Keyboard function
the keyboard is broken and needs to be replaced, try booting into dos mode and see if the problem persists
you can get a dosboot disk / cd from www.bootdisk.com
if the problem doesnt happen in dos then there is most likely a virus in you laptop. if the problem persists in the dos then the keyboard needs to be replaced.
Apr 14, 2008 | Toshiba Satellite A135-S2276 Notebook
IBM Wheelwriter 15
Keyboard connectors are not fully seated in main board or you need to replace the keyboard. You can send your board in for rebuilding for a cost of about $75.00.
Sep 17, 2007 | Office Equipment & Supplies
Computers & Internet Logo
18 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
