Kyocera kilburn raskalfa 180 reset
Kyocera kilburn raskalfa 180 how to reset?
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
1087 1087 then 163 reset it may prompt to turn off and on again,
if that does not reset copier replace the fuser assy
Mar 03, 2015 | Kyocera Office Equipment & Supplies
Erreur c6020 kyocera 180
Reset Procedure:
Enter 1087-1087 (1087 twice) from the keypad.
Enter 163 by using keypad.
Press "Start" (the green button) twice.
The machine will restart automatically.
May 15, 2014 | Kyocera TASKalfa 180 Copier
How to reset paper size select of kyocera taskalfa 180
1 Press the Paper Selectionkey for 3 seconds.The System Menu will be displayed.
2 Press arrow up/down repeatedly until 19.Cassette1Sizeappears, and press the OK key.
3 Press arrow up/down to select Auto Detect mm,
AutoDetect inch, Oficio 2, 8Kor 16K and press OK
Feb 28, 2014 | Kyocera TASKalfa 180 Copier
Reset code of kyocera 180
at first you go service mode in 10871087 then you press 163 and START
Nov 12, 2012 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
Master reset code Taskalfa 180
Kyocera mita task alfa 1800..error code 0800
Jan 18, 2012 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
jasbo
jasbo
