Question about Intex Easy Set 530 Gallon Swimming Pool Filter Pump
Filter pump wont start - Intex Easy Set 530 Gallon Swimming Pool Filter Pump
    Top Expert:
  • Intex Master
  • 5,673 Answers
Bad pump
Posted on Apr 27, 2016
I have a 2002chevy venture it wont start up it seems to be getting fuel an fire to the plugs it cranks but wont start spray starting fluid in it an starts but wont start on its on
How do you know it's getting Fuel? Sure sounds like it is not getting fuel since the car will Giggle when Starter Fluid is added.
Can you hear the Fuel pump run for a second when you turn the key to the RUN position?
Jun 07, 2015 | 2002 Chevrolet Venture
Why wont my yukon start after replacing gas pump and filter
If you replaced the fuel pump, you may have a line reversed or the fuel filter is backwards. Check for kinks. Make sure the new pump is working too. Sometimes it is possible to get a bad part.
Feb 05, 2013 | GMC Yukon Denali Cars & Trucks
1991 Chevrolet Camaro RS 3.1 wont start
The fuel filter is usually in front of the tank close to rear axle. GM had a lot of problems with the in tank fuel pumps. That is probably your problem but the fuel filter would be a good place to start. Also listen for the fuel pump running when you first turn on the key. It should run for a couple of seconds, if not you could have a bad fuel pump relay. Please rate my answer so I get points for it.
Jan 12, 2012 | Cars & Trucks
It wont start its beeps twice but does nothing. my wife told me it has not been draining well latley could the two be conected?
Check the filter near the pump or pump itself. If the washer wont start it is most likely detecting water still in the basket. Some washers have an inline filter before the pump and others have a external filter. They are designed to protect the pump. Check all drain hoses going from basket to filter to pump to drain. Check for kinks and also objects blocking the flow of water. Remove any obstructions and try again. The pump may have also went out. After checking everything see if the pump discharges water.
If you need further assistance or any questions feel free to comment.
Jul 27, 2011 | GE Washing Machines
I have a 92 lumina that wont start it cranks fine ..so i checked and im getting spark..so i moved to the fule i sprayed starting fliud and it started for the few seconds still fluid was gone, so i pulled...
Try changing your filter first if that does not work it could be your pump. It is possible for the pump to still pump fuel up through your filter but if it is not putting out sufficient pressure then your car wont start. Most fuel injection systems require around 35psi to fire the injectors.
Jul 17, 2009 | 1992 Chevrolet Lumina
Fuel problem, wont start
the pump is part of the filter/separator not in the tank no fuel will come out if filter is removed make sure there is fuel in the upper filter if there is the pump is ok it might be an oil pressure concern
May 10, 2009 | 2004 Ford F250
No start
no fuel to filter you say!! when you turn key on with out cranking it can you hear the fuel pump grunt grrrr? I would start with that!!!
Jan 07, 2009 | 2003 Dodge Sprinter
Intex Easy Set 530 Gallon Swimming Pool Filter Pump Logo
49 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
