Friedrich zq10a10a Squeaking noise
V6 engine knocking and squeaking noise
check for play in the distributor sometimes the slop will make the pick up window under the cap will hit the distributor cap , the squeaking noise may be your belt or tensioner pulley bearing the knock can also come from a bad tensioner as well .
Feb 16, 2014 | 1997 GMC Sierra
Friedrich wall unit whistles when turned off
it is the automatic valve when it is closed
Dec 14, 2013 | Heating & Cooling
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
Fan noise on Friedrich Model # CP12F10. Less than or about a year old.
Remove the shell of the unit and see if there is a obstruction in the fan,most likely is,if not look at the fan blades to see if they are tight on the shafts,if not,that is the problem.
Jun 09, 2011 | Friedrich CP06C10 Wall/Window Air...
Squeaking noise in engine. not serpentine belt.
You might have a dry bearing in the alternator. I've had a squeaking noise from them.
May 15, 2010 | 2004 Chevrolet Silverado
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Squeaking noises
First check the brake pads , a worn out brake pads may create a squeaking and grinding noise, if its delayed then you need to change rotors the brakes,get check ....
Good luck...
Feb 03, 2009 | 1999 Ford Explorer
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
