Question about HP Laserjet CM2320nf All-In-One Color Printer
Ready and Attention Lights blink and won't clear on HP CM2320nf printer
  • 4 Answers
SOURCE: HP 4350 printer
you might need to upgrade the firmware
Posted on Feb 11, 2008
  • 18 Answers
SOURCE: Printing problem in hP laserjet 1020
just inspect your printer's front cover.there r two plastic stick which is attached with the printer cover.this two stick hit the two particular point.
1.power switch conector(left side corner)
2. scanner sensor conector(right side middle)
i think your left side stick may be broke try it.
Posted on Feb 20, 2008
printech
  • 159 Answers
SOURCE: blank display
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
Posted on Apr 05, 2008
SOURCE: HP Laserjet 1320n Error Lights not in Manual
I confirm the solution is to switch formatter assembly
Part Number Description Printer Compatibility Notes
CB355-67901 Formatter, LJ 1320 (base model only) LaserJet 1320 base model only
CB356-67901 Formatter, LJ 1320n/tn LaserJet 1320n/tn
CB358-67901 Formatter, LJ 1160/Le LaserJet 1160/L
Q3990-67901 Formatter, LJ 1320nw LaserJet 1320nw
smapix@hotmail.com
Posted on Mar 22, 2010
  • 1684 Answers
SOURCE: CM2320 NF won't complete startup.
This usually indicates a failure of the fuser assembly. This part is what heats the toner to melt it onto the page called fusing. The fuser has a heat roller the turns when you print and when you initialize the printer. The clicking sound is cause when the heat roller is stuck and not turning and the gears are slipping. The clicking sound will come from the back right hand side if this is the case. You will need to get a replacement fuser assemble and swap them out. You can do a Google search for "cn2320nf fuser assembly" to get the correct part number. By the spelling of Colour I am guessing you are in either Canada or Europe so you may need a different part number than the US part, it would be based on line voltage either 110v or 220v
I hope this helps, if so please rate our solution.
BuddyMc
Posted on May 06, 2011
Testimonial: "Thanks for the help. I was on the right track and you confirmed what I thought. This forum has done it again. And, yes...I am Canadian."
How do i fix a 59.C0 error on my printer?
  1. Turn the printer off, and then turn the printer on.
  2. If the error message returns, turn the printer off.
  3. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. NOTE: If this message persists, you will need to contact an HP-authorized support provider.
Sep 15, 2015 | HP Color LaserJet CM2320nf MFP Refurbished
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
HP M2727 printer has FLASHING attention and ready lights
leave printer on, and unplug the power supply, then wait10 min. plug it back in, this should reset the printer, you might have to do this again and unplug any connections to your computer, wait and then plug in printer with power off and plug in connection to your computer, then turn on printer,, check your ink levels when you power up. if ink levels are low ,you could get this error. if this don;t work go to your printers website and check there solutions or you might have to call them.
Oct 02, 2012 | HP CB532A - LaserJet M2727NF All-in-One...
When printer is turn on that time printer reddy and cartridge light on so what is the problem
You can see four LED's on control panel, from top to bottom,1st is toner indication 2nd Attention 3rd is Ready light, 4th go light.. Observe led's are 'blinking' or 'On' condition.. # If toner light is blinking ="toner cartridge missing or contact problem or memory faulty.
# If toner light & ready lights are on= "toner low indication or refilled cartridge loaded".
Jul 12, 2012 | HP LaserJet P2015dn Printer
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
CM2320 NF won't complete startup. Stalls when initailizing after clicking sound and both Ready/OK light and Attention (!) lights flash continuously. LCD display is blank. Nothing in paper path. No...
BuddyMc
May 06, 2011 | HP Laserjet CM2320nf All-In-One Color...
The traingle is flashing orange the rest not flashing. the printer does not print
In the Attention state, the Attention light is blinking and the Go and Ready lights are off. This state can be reached in the following circumstances:
● Paper tray is empty
● Door open
● Toner Cartridge Missing
● Paper jam/ Tray Misfeed
Pressing Go attempts to reset after a jam is cleared or is ignored in the other error cases. It may be necessary to clear the error manually and press Go or close the top cover. If the error still persists, the device will return to the Attention state.
Note
The LJ1010 product series does not have paper out sensors. When the printer is in an Attention state because the paper tray is empty, the user must reload paper and press Go.
Nov 13, 2009 | HP LaserJet 1010 Printer
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
HP Laserjet CM2320nf All-In-One Color Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
