Question about Electrical Supplies
Want to put in ground fault switch in bathroom do they make such a switch
    New Friend:
  • 14 Answers
I have never seen a ground fault switch. You can however take power from the second brass screw on the GFI outlet. The outlet will protect the switch and light system. Look at the back of the outlet for "down circuit Hot" or something similar. If you need more help leave me a note on my site www.60cubits.com
Posted on Jul 11, 2013
  • Daniel Heap Jul 11, 2013
    The outlet I just looked t says "load" & "line". Load is power coming in. Line is out to your switch.
4 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Need to replace the light switch in my bathroom.
yes there the same type of switch,,just one is more up to date than the old one
Posted on Mar 28, 2010
al_kupchella
  • 843 Answers
If the switch has only two terminals besides the ground, then yes, they are equivalent. BUT, do you have a ground wire? If this is an old house without a ground wire you have been lucky with the metal faceplate, especially in the bathroom. The new switch is no more dangerous without a ground wire than the old one was, but there is a reason they put that ground lug on there. If you don't have a ground wire, get a plastic faceplate.
Posted on May 17, 2010
  • 5245 Answers
SOURCE: installing arc fault interrupter with ground fault
Question is vague. Arc fault and ground fault are slightly different.
Are you installing arc fault breaker?
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Code says Maximum 12 boxes per circuit breaker.
Arc fault breaker and GFCI outlet in bathroom?
>>> do not connect this way.
Do not install 2 fault protections on same circuit.
Install the arc fault circuit breaker, and then remove bathroom GFCI, and replace with ordinary outlet, or switch-outlet.
How many outlets can be connected to a bathroom GFCI?
It depends on total boxes on circuit.
Count the boxes. Max 12 boxes per circuit breaker.
How many amps can be connected to 15 amp device?
15 x 80% = 12 amps
Electricians use 80% rule to calculate safe maximum
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment
Posted on Apr 22, 2013
Installing arc fault interrupter with ground fault
If you meant arch fault with ground fault then no, the two types interfere with each other and trip the breaker as one senses an arch and the other grounding.
If you meant ground fault breaker with a GFCI. receptacle, you only need one of the two, either GFCI. breaker or receptacle.
and for circuits, you can put up to 12 devices (i.e receptacle, light)assuming they consume 1 amp each. Anything over 12 amps or 80% of the rating on the breaker, it will trip/reset.
Or if your talking about wires on a breaker then no more than 2 wires recommended. Try adding a junction box outside the panel if your trying to add other branch circuits or tap off of a receptacle.
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
15 x 80% = 12 amps
Add a comment
I am trying to install the light/outlet combo into my 80 year old bathroom. The outlet box only has 1 black wire and 1 white wire which come down from the top of the box...no other wires are available
If the wiring is BX cable (that is, the two wires are inside a flexible metal jacket that looks like a fat coil spring) (you would see the end of the metal jacket inside the box), and the box is metal, then the box is already grounded and you can install a jumper wire from the box to the ground terminal on the outlet. You might have to add a screw to the box. But if you don't have a grounded box, then the right thing to do is to rewire it all the way back to the main panel. On the other hand, if you simply skip the ground wire, the switch and outlet will work but they will be a little more dangerous than before because now you will have what LOOKS like a grounded outlet, but isn't. By the way, you should be using a ground fault protected outlet in a bathroom.
Good luck, be safe.
Oct 10, 2012 | Cooper Wiring Devices Combination Switch &...
Ground fault from box
In California It is code to have a ground fault receptacle where ever water is, Bathrooms, kitchen, laundry ect.
I have a older home that has 1ground fault for all receptacles located in the garage, so to update I have installed ground fault receptacles in all locations where water or dampness is present, even under the kitchen sink cabinets.
Apr 22, 2012 | Cars & Trucks
Wiring a bathroom in cellar need diagram for 2light switches 2lights and 2 recepticals
Set your boxes where you want them do be (be sure to check local codes for maserments and how many you need for want size room).
When you have that done go to the wiring.
Pick your power source and run a line 12/2 with ground to the room (again check codes for how many reseps and switches, lights you can have on one breaker).
You should have ground fault reseps any where you can reach a switch or plug from a water sources.
Don't put more then one ground faults one circuit they will fight each other and trip.
With the below drawings you should ready to go.
Good luck
http://www.bing.com/images/search?q=wiring+a+three+way+switch&view=detail&id=9C33873D5318C49207657934B6F2A7FEEC2C4EE9&FORM=IGRE1
Feb 01, 2011 | Home
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
May 15, 2010 | Leviton 1451-2ACP Grounded Quiet Switch
Mar 28, 2010 | Leviton 1451-2ACP Grounded Quiet Switch
No power in the two bathroom electric outlets.
What do you mean protected, if they where ground fault they have a test button,or the breaker
can be a ground fault, but it is a lot cheaper to buy the outlets. Call someone that knows electric,
because you need to check to see which outlet has power coming from the breaker,because this one
is probably bad, which will not allow any power continue on to the next outlet. Just say you were
going to do this yourself , you need a tester to make sure power is coming to the outlet.
You could buy a ground fault outlet and a regular outlet, but you have to make sure that the ground fault
is wired from the breaker, the power from the breaker, then the wire that Leeds from the ground fault
to the other outlet will also be protected, one ground fault can protect two other outlets that are connected to it in what is called a series. Unless you have a multimeter to test what needs to be tested
you should ask someone that knows electric. If you have any more questions please post back as everyone is more than happy to help. I don't feel comfortable trying to explain to you how to replace
the outlets, it can be dangerous and I would not want you to get hurt just to save a few dollars.
Mar 25, 2009 | Electrical Supplies
Installing timer on existing electrical outlet
Are the wires different colors or is there too many of one and not enough of the other. Your bathroom switch should have black which is hot, white which is neutral, and green or bare which is ground. It should be the same on the timer, but may differ. The instructions should tell which wire or terminal is hot, neutral and ground.
Sep 10, 2008 | Hardware & Accessories
Electrical Supplies Logo
44 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
