Rattling noises and blowing water (goldstar WG5005R)
We bought this ac unit a little over a month ago. Recently it has started making rattling noises and blowing out water where the cool air comes out. We've had a LOT of rain this last week so I don't know if that is the problem? I cleaned the filter but that didn't seem to help... Thanks to anyone who has some suggestions...
    Novelist:
  • 75 Answers
If the unit is new and tilted enough toward the outside, the rain should not be a factor as far as water blowing out. It will make some rattling noises on the outside more so when its raining or high humidity because the outside fan throws water onto the condenser coil. Sounds like to me that its not draining to the outside.. It shouldn't be dirty enough for the drain paths to be filled with crud. Tilting it more to the outside should fix it. Hope this helps. kstfas
Posted on Aug 27, 2007
  • 1 more comment
  • Ronnie Mason
    Ronnie Mason Aug 27, 2007
    P.S. I am supposing this is a window unit. If not, The above suggestion may be printed and thrown into the trash can. Ha. Have a nice day.
    kstfas
  • ACopley Jun 01, 2013
    Hi, Ronnie. Actually it's a portable floor unit. Thanks anyway.
    Actually, when opening the unit, I noticed there was crud on the condenser coils. I was told a good solution of Simply Green and hosing the crud off would do. Not sure if this would mess up the electronic panel. Any suggestions on how to clean it?
    New Friend:
I have the same problem. I can't get the water to drain. I almost have to trun it on its side to get the water out. ONce it fills up, the fan splashes on the water accumulated inside. I bought two drill bits to drill holes in the bottom. I thought I would get an answer here, but it seems to me that the best solution is to drill the hole. I suggest you get a thin metal bit to make the guide hole, and then a bigger one to finish it off. The thing you need to be most careful about is not puncturing a freon line. If you do that, you might as well toss it. I would even consider opening up the unit, and drilling from the inside out to avoid piercing a line or accidentaly hurting something else.
Posted on Jun 29, 2010
SOURCE:
05 buick rendezvous overheating recently changed thermostat heater blowing cold air when runs hot
Sounds like you may have a head gasket leak. But first I would check the water level and get the air out of the system. Air is bad is water system. When bleeding the air squeeze the hoses to burp the air out and I also would suggest looking for a purge nut on the top of a water line or housing on the engine. Check the fan is working or works. And then maybe consider the thermostat was installed wrong.
Dec 22, 2017 | 2005 Buick Rendezvous
Air is not cold, and a wierd cracking noise
You are required to get the AC serviced which you can do it yourself except the checking of cooling gas. Unplug the power cord. Remove the AC from the frame. Take it near to a water point where it can be washed. Remove the front filter and clean it with a mild soap solution. Next take a water pipe and spray water jet in the air vents/fins. Let it dry. For cracking noise connect the power cord and run the AC locate the noise. If it is any loose part fix it or provide necessary packing to avoid vibration noise. When you are running the AC check if there is moisture condensation on the cooling pipes. If it is there then the gas is OK otherwise you have to top up the cooling gas. If the sound is coming from the compressor then you have to change the compressor. Re assemble if you are satisfied that the gas and compressor defects are not there.
Jun 28, 2010 | Heating & Cooling
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
Air coming out of vent very low and not cold
Try cleaning the coils with a wire brush and soapy water.
Aug 11, 2009 | Whirlwind FH-778 Air Conditioner
Loud rattleing sound
If this AC is a thru walled, since it is new it is better to inquire to the people where you buy this unit, for this type of problem. They must have some authorized repair man/shop or, use its product warranty.
The problem could be also uneven placement of its base. This could maybe hitting the fan guard, some loose connection or some foreign object left that's hitting something inside.
Jul 31, 2009 | Kenmore 75085 Air Conditioner
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
Jul 25, 2009 | Heating & Cooling
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Jun 16, 2008 | Heating & Cooling
Heating & Cooling Logo
1,461 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
