Question about Bose 901 EQ1915 Home Equalizer
Can I run two stereo amps from same preamp?
There are two amp outputs on the back of my Adcom GFP 555 preamp,one labeled "lab" which is running my Adcom GFA 555 amp in stereo mode and another next to it labeled "normal"that I would Like to hook up to a Carver PM900 in stereo mode and run both at the same time. Neither one will bridged mono but both will be run stereo.Can I do this?
    Master:
  • 483 Answers
Yes, and do tell, what speakers are you powering with these amps?
Posted on Jul 13, 2013
2 Suggested Answers
richardbramb
SOURCE: hooking up my bose 901 e q to my adcom 600 preamp & adcom 555ll amp
hook up inline outline plugs on back were do they go to
Posted on Feb 20, 2012
How to connect a yamaha p7000s amp to an adcom gfp-555 preamp
Use "Main Out Norm" from the gfp-555 pre-amp and connect to Canon connectors of the Yamaha. This requires a standard RCA to Canon cable for correct connection. Start with this first, if that works OK than try the "Lab" output of your pre-amp, but I am not sure if the Yamaha can handle this or the results of sound quality. Your choice.
Feb 17, 2016 | Yamaha Audio Players & Recorders
Help! My Adcom 555 amp and Adcom preamp is making a buzzing noise in one speaker - any ideas on troubleshooting - is it the preamp or amp?
Try a different audio source.
Disconnect the cable at the preamp end from the amp and see if it stops.
If it does = preamp.
If not = cable or amp.
Reseat cables at both ends with a twisting motion.
Swap left to right.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Lots of ways to eliminate sources of the fault and isolate the problem.
Mar 12, 2011 | Audio Players & Recorders
I have a ADCOM GFP-710 Stereo preamplifier when I turn in on, it will only stay on for 1 second. That's it. Any ideas? Thanks, fred.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 14, 2011 | Adcom GFP-710 2-Channel Amplifier
Adcom gfa 555 blows the 10 amp fuse and the 6 amp fuse on the far right
Any fuse blowing is caused by a shorted component in either the power supply section or main audio amp part. Follow the fuse circuit and see where it leads you. Look around for burnt of damaged parts. Suspect anything sitting on a heat sink. The most common culprit is the audio amp main transistors, especially if someone shorted the speaker leads together. In the power part it could be the transformer, the large Electrolytic capacitors, rectifier, or voltage regulator. Some amps use an IC for amplification and this can blow the fuse.
Oct 19, 2009 | Adcom GFA-5500 2-Channel Amplifier
I have a problem with the Main Output on my Adcom 710 Preamp
Hi am gathering that when it is bypassed (tone) its fine which suggests that the problem is on the treble/bass pots or boards. Try cleaning all the pots with switch cleaner first (open the amp and spray it into the pots them selves through little holes). If not there then Check for a loose wire, and can also tap the boards with back of screwdriver while the amp is playing to listen for dry joints (loose solder and CAUTION for getting a shock also!!)
Pretty sure though on the pots or dry joints.
Best of luck
Jul 24, 2009 | Adcom GFP-710 2-Channel Amplifier
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
How to bridge GPA 555 adcom amp from 8 om to 4 om
First of all, when bridging an anp, the impenence that it can handle usually goes UP not down. I don't believe that the GPA555 can be bridged without circuit modification.
Dan
Feb 11, 2009 | Adcom GFA-5400 2-Channel Amplifier
Bose 901 EQ1915 Home Equalizer Logo
321 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
