Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
Only freezes the bottom half
My freezer is still freezing, but only the bottom half. The top half is completely defrosted. The green light on the front stopped working a long time ago. It doesn't sound like it ever 'clicks' on or a fan is running. Where should I begin and continue looking for the issue?
4 Suggested Answers
fixitallguy
  • 11 Answers
SOURCE: green light
could be a possible short in the electrical
Posted on Jan 25, 2008
  • 396 Answers
SOURCE: seemed to be running all the time, not freezing,
Have you cleaned the coils underneath or in back of the unit?
Posted on Oct 10, 2009
Testimonial: "Thanks for the tip, it seems to be working although I hesitate to fill it! Thanks again"
  • 272 Answers
SOURCE: we have a freezer full
Greetings,
This type of freezer has few controls to malfunction...is the compressor running? if it is...then, its most likely a sealed system problem....if not running...find the cold control and jump out the connectors..if it off due to bad control..this will bring it back on. the other thing that could keep it off is the relay..again, if cold control ok, then remove relay and shake it..if it rattles..its bad, This you need to actually replace. there is no temp fix...if everything I mentioned is okay and freezer compressor is actually running...its most likely a system failure and usually its one year from date of purchase
Bruce
Posted on Nov 25, 2010
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
The top haft stop freezing
Without looking at it it's hard to say for certain, but most likely it's low on freon. It could also be a defrost heater not working properly.
May 12, 2014 | Whirlpool Freezers
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Top half does not freeze
There is a fan behind the back wall of the freezer about 1/2 way up from the bottom, you should be able to hear this running when the freezer is on. If you do not hear this then you need a new evaporator fan motor.
If you hear the fan run then you most likely have a problem with the automatic defrost cycle that would most likely be the heat element that is located just below the coils inside the freezer behind the panel.
Apr 21, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Upright freezer
If it has a fan in the freezer it need to be running to circulate the cold air.
If the coils are not icing up evenly from top to bottom you have a system low on freon.
The light frosting is normal.
A model number would really help to troubleshoot the problem.
Sep 19, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
My freezer is freezing at the bottom but is not at
Short on refrigerant would be a good starting point, pressure temp relationship should be tested by an opperative.
Jun 27, 2009 | Hoover 9.9 cu. ft. / 280 liter Upright...
Fridge/freezer won't cool completely or freeze
Things to look for and fix yourself woulf be to clean the coils on the bottom and check the fan motor on bottom, make sure it is ok, Look on back of the freezer walls for frost buildup, a sign the defrost heater is dead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2009 | Freezers
Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Jan 21, 2008 | Freezers
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
kfinlay1969
Level 1 Expert
Are you a Danby Freezer Expert? Answer questions, earn points and help others
