How to setting paper in epson lx-310 - Office Equipment & Supplies
How to change paper setting from photo paper to A4
go to settings at the print and find the paper option settings
click on a4 paper and apply settings
Mar 02, 2016 | Epson Expression Home XP-310 All-in-One...
Epson xp-310 will not print Canada government forms
It could be something as simple as the paper size. Go into printer preferences in the printer menu on the computer. Check the default paper size is appropriate for your area (either Letter or A4) and then check (tick) scale to fit paper. Save this as your default settings.
Mar 02, 2015 | Epson Office Equipment & Supplies
My Epson xp 310 won't print on cardstock; paper just glides through blank
to be able to print with a ink jet printer, the surface of everything is supposed to be prepared for the ink. When the printer prints fin on "normal" paper, it can print all all surfaces you can fine in your printer settings.
Feb 19, 2015 | Epson Expression Home XP-310 Small-in-One...
Epson lx - 300+ ii borderless
If you know how to set the margin to 0.00, just set it and send a print-job. You will see what happens.
Oct 31, 2013 | Epson LX-300+ II Matrix Printer
Epson LX-310
on epson LX-310 font draft condensed is not available, so if you want it, you must downgrade your printer. i don't know, why epson doesn't do this :(
if you want send raw data to printer, use escape command
Apr 24, 2013 | Office Equipment & Supplies
In EPSON LX-300+ printer need to set up the page size,i could manage to set up the paper size,but it was countinuous paper,so it has line to tear off.,but after finishing the printing in one page,next...
First check what paper size u want, then set the same size in the printer menu. Next go to Printer properties paper setting change it there , then advance change the size, printing preference again check both the options to the prefered size.
Your printer must work now with all these options
Feb 17, 2011 | Epson LX-300+ II Matrix Printer
Font and paper size are not fit with the desire size
pls check the paper size in priter option may solve ur problem
Sep 08, 2009 | Epson LX-300 Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Setting of new paper size from epson lx-300 +II
your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Apr 13, 2009 | Epson LX-300+ II Matrix Printer
Small Height Paper Size Problem
here's an option for you to consider.... hope it helps!!!!
set it to 3.6 and make your adjustment on the page margins.
Feb 28, 2008 | Epson LX-300+ II Matrix Printer
2,428 people viewed this question
jasbo
jasbo
