Question about Microwave Ovens
Sharp carousel microwave manual r4208 - Microwave Ovens
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
Posted on Oct 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: sharp carousel microwave doesn't spin
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835
Posted on Nov 21, 2008
SOURCE: R1381 Sharp Carousel over the range microwave
I know this is late, but I have instructions for this unit. Remove the grease filters on the bottom. Inside the exposed hole there should be two gold colored bars. These are attached to plates at the top of the until which hook onto the mounting plate. Undo the screws at the bottoms of the bars and pull them down. This will unhook the unit from the top of the wall plate. Roll the unit forward and unhook from wall plate.
Posted on Feb 18, 2009
fieldy14
  • 456 Answers
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
Posted on Aug 16, 2009
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
NEED MANUAL4 SHARP CAROUSEL MODELR403KK SERIAL 173160
You can download the owner's manual from my site here at no charge.
May 31, 2012 | Sharp Microwave Ovens
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
R-425LS 1100 Watts Microwave Oven: I need a manual for the sharp carousel R-425LS...
http://www.sharpusa.com/~/media/186C050CCE1F4A99ADC5FA230942E483.ashx
May 18, 2010 | Sharp R-425LS Microwave Oven
Sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Dec 27, 2009 | Sharp Microwave Ovens
Aug 16, 2009 | Microwave Ovens
Sharp carousel convection microwave model r9h10 user manual
I can send you the instruction manual for Sharp R-9H10. Please send your mail address.hgclanka@hotmail.com is mine
Jul 06, 2009 | Sharp Microwave Ovens
I am looking for a manual for a microwave it is a sharp carousel model R-380C.
go to the sharp site and look up your model #. they should have it for you there or be able to get one close to what you have.
Apr 09, 2009 | Sharp Microwave Ovens
MANUAL WANTED TO DOWNLOAD
Check out the manual download section at www.sharp-usa.com
Jun 22, 2008 | Sharp R-353 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
