Question about IBM ThinkPad T30 2366 Notebook
T30 led's I just attempted to replace my LCD screen. My parts T30 had a screen capable of more resolution. Well it didn't work. The screen would backlight, but nothing else. So I put the old screen back but now I have lost all of my green LED's for indicating charge, hard drive in use, caps lock etc. What's the deal with that? any ideas.
Yes, this is most definitively realted to this small "inverter board". Perhaps the flatcable is torn due to the mechanical work, or one of the connectors is out. Careful: the invertor board generates High Voltage to power-up your TFT lighting. Btw, are you aware of any place where I can buy a T30 TFT XGA 14.1" 1024x768 as a spare part? I am looking for normal prices, what I found thusfar was way too high... Thaks for any hints. Peter pfrank a hetnet . nl
Posted on Sep 04, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
A small board that attaches to the mainboard via a small cable has come unplugged. remove the lcd bezel and check connections rto te motherboard itseld from a small daughter card.
Posted on Aug 26, 2007
SOURCE:
The Screen turns black when I attempt to start windows normally. It sounds like windows is starting, but nothing appears on the screen
It sounds like windows has been set to a screen resolution beyond the limits of the capabilities of the built in LCD. Luckily windows has a menu that allows you to change to a highly compatible low resolution mode. To select this mode, start tapping the [F8] key just after the HP/Compaq screen when the computer switches on. Hopefully if you pushed the button in time, you should be presented with a menu. Use the up and down arrows on the keyboard to select the option that says either "Enable VGA Mode" or "Enable Low Resolution Video (640x480)".
Windows should now load, but everything will look extra large. To fix this, go into your display properties (right click on desktop and select either "properties" or "screen resolution"), and choose the recommended screen resolution.
Dec 24, 2010 | Compaq Presario CQ60-220US PC Laptop
Ineed to replace my display card for to get a
Try this. Make sure you are at the desk top screen. Right click your mouse click on properties. When the display properties comes up select the settings tab. Now you will see the display properties and you can adjust tho get a higher resolution screen. Hope this helps.
JimmyC
Sep 27, 2009 | Sony VAIO Digital Studio PCV-RX540 PC...
Can i replace my Gateway laptop tft screen with a new lcd screen?
The screen resolution is a combo of:
  1. the screen's capability
  2. the video card's capability
  3. the driver's settings
If the above screen is made for this laptop (as it appears to be), then the settings you had should still be there.
Jul 29, 2009 | Toshiba LCD TFT Monitor
When the cursor is moved to the right or to the bottom of the screen, the entire view shifts left or up and a garbleb image aoppears.
If the screen picture moves then you have the wrong resolution set for your monitor and part of it is extending beyond the monitors capabilities. This is common if using a laptop.
Try going into you display properties on your computer and lower the resolution of the display.
If you search your monitor model, you should find the resolution that it is capable of.
1600x1024 may be the maximum. (not all video cards support all resolutions so you may have to choose another widescreen format)
Jun 20, 2009 | LG Flatron 295LM 22" LCD Monitor
Display Problem
video card may not be capable of that resolution and color depth, check your video cards max resolution and color depth.
I have several lcd monitors that are 1280x 1024 and they do not need drivers to work. the video card must be capable of generating that resolution.
Jun 06, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Thinkpad T30 - LCD Not working
I dropped my laptop and screen was verry hard to see unless u shined a bright light at it. the inverter just under the lcd screen happened to come unpluged. I dont know if i was just lucky or if this has happened to more people. I hope this helps some one else.
May 11, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 LCD replaced - now LCD display not right resolution
Yes you can do that by trying to set the sesolution settting.
Step for setting up screen resolution
1.Click start-->Settings-->Conteol Panel-->Display
2.Under Display Properties window click the last tab name settings
3.Below you should be able to see Screen Resolution
4.Try to adjust the resolution here.
** Please try to reduce the resolution ...or sometime add more resolution
takecare.
Apr 29, 2008 | IBM ThinkPad T30 2366 Notebook
Resolution 16-10
Your resolution is based on your video cards capabilities. If your still using the original on-board, integrated video I doubt if you'll be able to reach such resolution. Open control panel, open Display. Click the Settings Tab. You will notice Screen resolution & there is a slide bar. Sliding the bar to More will increase the resolution. You'll see what the max is for your video card. As to your LCD monitor it's max resolution is capable of reaching 1680x1050. Keep in mind the word " capable ".
If you need that kind of resoluton you'll need to find a AGP video card that can go that high.
Please vote.....
Jan 30, 2008 | Computers & Internet
Resolution
To set the resolution just Press the MENU icon (middle icon) on the left side of the LCD screen. Then press the QUALITY icon (lower row left icon). Choose from one of the four icons.
Sep 11, 2005 | Toshiba Sora PDR-T30 Digital Camera
IBM ThinkPad T30 2366 Notebook Logo
112 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
