This washer trips the house main board when a program is selected, it does not trip when just the washer on off switch is pressed lighting up the washer panel although it will switch off on its own after a short period and will not switch back on again for some time.The filter is clear,the drum turns and the plug socket works ok with other loaded appliances without tripping. Is this a common problem with this washer as its obviously shorting out or leaking to earth somewhere ?
Thankyou for taking time to answer Rick
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Hi Ben Thank you for replying to my question.
Actually the washer was empty with no program selected when i switched it on. The panel lights up but goes off after a short period and does not come back on for quite some time. When a program is selected it trips the main board. Some one else has come up with the same answer as yourself so i am off to in investigate the problem !
I will return !! Rick
